Activity Forums VEGAS Pro vcr to Vegas 12
  • John Rofrano
    February 19, 2018 at 9:18 pm
    [Jack Gill] “Perhaps I don’t understand how to make the connection to Vegas 12”
    Well the first thing you need to do is make sure that Windows 7 can connect to your device. I have the Canopus ADVC300 but the ADVC100 should look very similar.
    In your Windows 7 Device Manager, under Imaging devices do you have a device called AV/C Tape Recorder/Player?
    If you don’t see this device, then Windows 7 can’t see your Canopus ADVC100 and Vegas Pro will never see it. So let’s start there.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Jack Gill
    February 19, 2018 at 10:45 pm
    I’ve got it!
    Jack
  • Jack Gill
    February 20, 2018 at 5:23 am
    John, I noticed that I see AV/C Tape Recorder/Player only when my Canopus is turned on.
    Jack
  • John Rofrano
    February 20, 2018 at 12:23 pm
    [Jack Gill] “I noticed that I see AV/C Tape Recorder/Player only when my Canopus is turned on.”
    Great! Yes, the device is a “real” device so if it’s turned off Windows won’t see it. That’s great news, that means that Windows 7 can see your ADVC100.
    Next, with the ADVC100 turned on, in Vegas Pro 12 when you go to File | Capture Video… to capture your tapes, do you see this dialog box pop up and do your select DV? (you should)
    That should bring up the VidCap program that captures from DV tape.
    And you should see the window above. Do you get that?
    ~jr
  • Jack Gill
    February 20, 2018 at 3:14 pm
    When I get to the vidcap screen it references Manycam, which I have on my computer. I have a blue box that says preview is turned off, even tho I have it turned on. Boy, here’s where I start to get real confused!!
  • John Rofrano
    February 20, 2018 at 3:39 pm
    [Jack Gill] “When I get to the vidcap screen it references Manycam, which I have on my computer. “
    I’m guessing that this is your problem right there.
    Open the Video menu from the top menu bar and select your Canopus ADVC100. That should make it talk to the Canopus device instead of Manycam and allow you to capture your tapes.
    ~jr
  • Jack Gill
    February 20, 2018 at 6:32 pm
    BINGO!!!!
    That did it. Now recording. Thanks so ever much John and the others who pitched in.
    Jack Gill
  • Francois Blawat
    February 20, 2018 at 9:40 pm
    Thank you John Rofran for referring to that Article about using Legacy Drivers under Windows 7. I have an ADVC-55 and I was having issues. These forums are great for resources and help.
    FixitMad
  • John Rofrano
    February 21, 2018 at 11:16 pm
    [Jack Gill] “BINGO!!!!”
    Ding! Ding! Ding! We have a WINNER! ????
    You are very welcome… Glad you got it working.
    ~jr
  • John Rofrano
    February 21, 2018 at 11:18 pm
    [Francois Blawat] “Thank you John Rofrano for referring to that Article about using Legacy Drivers under Windows 7”
    Great! I’m glad that helped. I have a bunch of tapes that I have to sit down and capture so I’m about to go through the same thing with my ADVC300.
    ~jr
Page 2 of 2
