Activity Forums DaVinci Resolve v9 grade into v10 grade = different grade?
  • v9 grade into v10 grade = different grade?
    Posted by Dennis Hingsberg on February 19, 2014 at 7:39 pm
    Anyone else try a grade exported from version 9 and importing it into version 10 and experiencing different results on the the SAME clip?
    I am, so just wanted to see if anyone else has tested or tried it/
    cheers
    Andrew Sableton replied 12 years, 7 months ago 4 Members · 5 Replies
  • Clark Bierbaum
    February 19, 2014 at 9:11 pm
    Thought I was crazy! But guess it must be true! SOME corrections taken from stills of previous sessions don’t match, haven’t loaded an old timeline. Some only one node of primary correction.
    This is NOT cool!
    Clark Bierbaum
    Color Grading / Post Consultant
    GarnetColor.com
    Charlotte, NC
  • Dennis Hingsberg
    February 20, 2014 at 4:44 pm
    this is totally not cool and needs to be addressed, I can’t possibly move to 10 without the ability to preserve my grades.
  • Juan Salvo
    February 20, 2014 at 5:49 pm
    If you update your database as opposed to importing a “drx” then your grades will be consistent. The issue here is with bringing a drx (not a drp, btw) directly from one version into another without the math being adjusted.
    If you import a drp that also gets updated.
    That said, theres still a chance thing might look slightly different from version to version. Debayer, noise reduction, blur/sharp algorithms get updated and change. Hue vs math gets changed. ACES versions get updated. Etc, etc. This could effect the way your image looks.
    If you want perfectly consistent results, you shouldn’t upgrade in the middle of a project.
    https://JuanSalvo.com
    https://theColourSpace.com
  • Clark Bierbaum
    February 20, 2014 at 10:59 pm
    Good info! The only problem with waiting to upgrade is that sometimes clients come back months later with revisions!
    Clark Bierbaum
    GarnetColor.com
    Charlotte, NC
  • Andrew Sableton
    February 25, 2014 at 7:36 pm
    That’s why you will always keep at least one previous version of any piece of major production software on a cloned bootable drive. There is no problem here at all.
