Activity › Forums › Apple Final Cut Pro › Using FCPX to make informercial vs Motion
Posted by Jim Kehoe on August 27, 2014 at 3:54 amHey guys,
I am going to be making an infomercial and was wondering to intermix using the kinetic text features in Motion as opposed to doing the text in FCPX, any thoughts on workflow? Basically i want all the cool pop ups that infomercial have and the glowing text, etc I need it to look pretty cheesy, it’s for a project that is spoofing a legit infomercial. LOL
Jim Kehoe replied 11 years, 11 months ago 3 Members · 13 Replies -
Jeff Kirkland
August 27, 2014 at 5:06 amWell, I make real informercials and I do 90% of my onscreen stuff in FCPX. It’s pretty rare that i have to go beyond key framing or the canned text animations, effects, etc to get what I need.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Jim Kehoe
August 27, 2014 at 5:25 amHey Jeff! Thanks for the reply! So what you’re saying is all the key framing for the infomercial can be done in fcpx correct? I’ve actually never key framed in fcpx but I’ve done a lot of key framing in motion.
Jeff Kirkland
August 27, 2014 at 7:47 amAll depends on how over the top it needs to be. For me it’s mostly just text zipping across the screen, flashing, growing, spinning, etc so all of that can be done in final cut. If you need a fancy path, or niceties like ease-in, ease-out, then I head over to Motion.
Jim Kehoe
August 27, 2014 at 7:52 amThanks Jeff! Now do you sometimes do the entire infomercial in motion if you go with more fancy stuff?
Jeff Kirkland
August 27, 2014 at 8:46 amNot usually. Most of my stuff is 28 minute long form so it’s all Final Cut. Everything is edited first, then motion graphics added, then if anything needs to be done in motion, I’ll export that segment, do my animation, then often publish it back to final cut as a title or generator or whatever – on the basis that if needed to do it once, I’ll probably want to do the same thing again in the future.
Robin S. kurz
August 28, 2014 at 9:07 amThis is certainly not something you’d want to do in Motion, no. Motion is by no means an NLE. If anything, then you would simply make TEMPLATES of any needed specialty titles/title animations and publish them to FCP for further customisation as needed. For example if there is a default title template that you like, but just need a few tweaks, simply open a copy in Motion with a simple right-click on it in FCP, make the needed changes and save. That’s why it works the way it works. 😉
Jim Kehoe
October 8, 2014 at 2:05 amHey Jeff! Had a quick question for you, here is a link to an infomercial, so this is all possible to do in fcpx? Gonna be making a really cheesy one for a music video LOL
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jeff Kirkland
October 8, 2014 at 3:53 amYep, no problem – with the exception of the the particles and 3D stuff which you’d have to create somewhere else, then import.
Jim Kehoe
October 8, 2014 at 4:00 amright on, thanks Jeff! i doubt i will use particle, probably just some glowing text effects
