Activity › Forums › Blackmagic Design › Using Blackmagic shuttle usb 3.0 with m11x problems
Mike Squires replied 14 years, 6 months ago 3 Members · 93 Replies
Mike Squires
March 6, 2012 at 2:12 pmSounds like you need a faster hard drive. Until you get one, try capturing in SD, using the DVCPro50 codec.
Louie Baffoe harris
March 6, 2012 at 5:07 pmhow do i go about setting that up i seem to be doing it wrong
Mike Squires
March 6, 2012 at 5:13 pmSet the Xbox to output standard definition (SD). In Premiere Pro, set the sequence to Blackmagic Design-PAL-DVCPro50-4×3 (or 16×9).
After pressing F5 to open the capture screen, make sure to set the Shuttle to capture at those some presets.
Louie Baffoe harris
March 6, 2012 at 5:19 pmmy xbox allows me to set it to 480p but the dvcpro50 options are 480i and 576i i tried the 16:9 widescreen 24p option in 480i to try but no dice
ignore i didnt go through blackmagic design drop down trying again.
Mike Squires
March 6, 2012 at 5:26 pmOk, the XBox doesn’t want to output 480i, so that isn’t going to work.
Try going back to 1080i, and using the Blackmagic Design/HD1080/AVCHD codec.
Louie Baffoe harris
March 6, 2012 at 5:36 pmi tried it again properly i didnt select the the drop down correctly like the first time,
im going to try the avchd suggestion now how do i select the avchd options for standard definition? -
Mike Squires
March 6, 2012 at 5:37 pmIt’s not SD, it’s HD, but I’m hoping your hard drive can handle AVCHD, instead of DVCProHD.
Louie Baffoe harris
March 6, 2012 at 5:46 pmah i see, im on the menu before the sequence im not sure how to config the shuttle correctly my drop down are options are video standard and video format, ive set standard to 1080i 59.94 which should be fine but the video standard has uncompressed 8 bit,uncompressed 10 bit, motion jpeg and dvchdpro.
which should i select before i pick the avchd sequence? does it even matter which i pick too?(for now ive picked uncompressed 8 bit since that is the default till you can guide me)
Mike Squires
March 6, 2012 at 5:59 pmAh, you’re right, it can’t capture directly in AVCHD.
Do you have the XBox360 adapter that has s-video outputs? If so, you can use that for SD interlaced.
Louie Baffoe harris
March 6, 2012 at 6:27 pmi have this
the red white and yellow is that good enough?
Also what settings should i use with these
also for my system which ssd should i purchase that will allow me to avoid all of these issues?
