Activity › Forums › Blackmagic Design › Using Blackmagic shuttle usb 3.0 with m11x problems
Mike Squires replied 14 years, 6 months ago 3 Members · 93 Replies
Louie Baffoe harris
March 1, 2012 at 7:57 amhttps://forums.adobe.com/message/4143890 also i found this tread stating something about the usb being powered, thoughts?
Louie Baffoe harris
March 1, 2012 at 9:34 ami went back to media express to try it out, i made 2 vids the fighting game one in the image was covered in lines and the 2nd was alot better though at certain times i had lines on menus where i was scrolling fast,i randomly and selected avi motion jpeg and thats the results i came up with i was able to capture and everything went pretty smoothly (came up with the dropped frame screen once) there was defo a bit of lag in the preview window but i rocked with it and got a 750mb file and some of it was quite blurry like shown in the pic i had the black magic shuttle control panel settings to have input processing from 1080i to sd letterbox but i dont know if it actually affected it.
Mike Squires
March 5, 2012 at 5:14 amSorry Louie, been busy with a live gig. Will get back with you tomorrow morning.
Mike Squires
March 5, 2012 at 4:14 pmLouie, looking at your screenshot, that’s looks like an interlacing issue. Try inputting and capturing at 720p.
Louie Baffoe harris
March 5, 2012 at 9:00 pmi see ill try that now, the vids dont seem too smooth whe recording and sound can get glitchy is there any other codecs/recording format i can try that are good but not so intensive maybe? it seems my hard drive at the moment is bottle necking me
Mike Squires
March 5, 2012 at 9:02 pmLooking at your speed test results, you really shouldn’t have any problems capturing in DVCProHD, of course you have to use Premiere Pro to capture if you went that route.
Louie Baffoe harris
March 5, 2012 at 10:15 pmalso im wondering i can set my screen xbox to show 50hz or 60hz both hz work but im not sure so i checked around apparently UK is 50hz in general so i set it to that
Louie Baffoe harris
March 6, 2012 at 1:40 pmhmm so i tried it again and the video is really laggy like 25% speed
when i tried with dvchdpro it just wont record for more than 2 seconds before frames drop and capture aborts
motionjpeg is the only one that works but its laggy and sound is still glitchy what should i try?
