Activity › Forums › Blackmagic Design › Using Blackmagic shuttle usb 3.0 with m11x problems
  • Louie Baffoe harris
    February 29, 2012 at 4:23 pm
    awesome then comes out to about 12.5 p/s which is is about 1/4 the speed of my drive afaik,
    soo.. Can i hit record now?!?!
  • Mike Squires
    February 29, 2012 at 4:27 pm
    One more thing, in the capture menu, click on settings in the upper right corner, and make sure your capture locations are where you want them.
    After that, you’re ready to rock n roll.
    February 29, 2012 at 4:29 pm
    excellent im ready for phase 1 ill post about how it goes, if i have my browser open in the background is that a bad idea i guess its just taking up ram for no reason? or is it fine got 4gb not sure if thats enough or more than enough
  • Mike Squires
    February 29, 2012 at 4:32 pm
    The browser being open shouldn’t be a problem, just leave it in the background.
    alright ill be back with results.
    February 29, 2012 at 4:51 pm
    okay so i just tried to record just now, and i seem to be getting that dropped frame shenanigans i got when i tried it on blackmagic express, i think it has something to do with my drive, the video didnt last more than 2 seconds is the rate too high for my laptop?
  • Mike Squires
    February 29, 2012 at 5:06 pm
    In Premiere Pro, press “F5”, click on “Settings”, click on “Edit”, and make sure the capture rate is set to DVCProHD.
    March 1, 2012 at 5:59 am
    I believe i have set as such i went to try record again and it was still no luck 🙁 any thing else i should try.
  • Mike Squires
    March 1, 2012 at 6:02 am
    Do another speed test for your hard drive. Using the Blackmagic Speed Test software. Tell me your readings.
    March 1, 2012 at 6:18 am
Page 6 of 10
