Activity Forums Adobe Illustrator user defined scale?
  • user defined scale?
    Posted by Peter Wu on January 24, 2020 at 8:24 am
    Let’s say I’m creating an inforgraphic showing world famous buildings in corrrect proportion.
    Perhaps each 1000 feet could be scaled to 2 inches in the infographic, but I don’t want to do the scaling myself. Is there a way to enter the building height in feet and have illustrator scale to 2 inches, kind of like CAD programs?
    If the answer is no, then what is the best solution? Manual scaling? Or use another program (which one?) to create the infographic?
    John Stanowski replied 6 years, 6 months ago 2 Members · 1 Reply
  • John Stanowski
    February 27, 2020 at 9:33 pm
    You can enter simple mathematical formulas into the height and width fields and Illustrator will do the math for you.
    In your case, take the building that is 1000 feet tall.
    Pretend it’s 1000 inches tall.
    Draw the rectangle. And then in the Properties Panel, find the Height and enter in 1000*0.002
    Your rectangle will now be 2 inches tall. And you can label that anything you want.
    Use the same formula for the rest of the heights of the other bldgs. Just alway enter the Height followed by *0.002
    2013 Intel MacPro
    3.5 GHz 6-Core Intel Xeon E5
    64 GB 1866 MHz DDR3 ECC
    AMD FirePro D500 3072 MB
    Software OS X 10.14.3
    Adobe CC
