Activity › Forums › Adobe Premiere Pro › “use preview files” export question
  • “use preview files” export question
    Posted by Tom Gomez on October 17, 2011 at 9:02 pm
    Greetings Folks,
    I completely rendered my timeline (green bar all along the top). Sequence is under 2 mins.
    When I export, I select “Match Sequence Settings” and “Use Preview Files.”
    But it still takes several minutes to export. If the whole thing is rendered, and I’m using the preview files with export settings identical to my timeline settings… shouldn’t it just be gluing preview files together and therefore exporting at lightning speed? I want to make sure it’s not re-encoding somehow.
    THANKS!!!!
    Tom
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
    Tom Gomez replied 14 years, 11 months ago 3 Members · 4 Replies
  • Jeff Pulera
    October 18, 2011 at 3:24 pm
    Hi Tom,
    Mac or PC? Processor? Source material? What are you exporting to – H.264? MPEG-2?
    Even if using previews, AME still needs to convert your video to whatever format you are going to, it is never instant.
    Jeff Pulera
    Safe Harbor Computers
  • Ann Bens
    October 18, 2011 at 7:34 pm
    Don’t use match sequence and dont use Previews.
    With match sequece settings you can end up with the wrong codec settings like just I-frames mpeg. This settings is only use full for DV.
    Preview files are of low quality. They are for preview.
    If you just want a quick output for say testing its a good option, but otherwise dont use them. Use a preset and Max Render Quality.
    Adobe Certified Expert Premiere Pro
  • Tom Gomez
    October 26, 2011 at 4:47 pm
    I just don’t understand why it would need to do any converting at all if the source format is identical to the export format and there aren’t any filters or anything? Shouldn’t it just be gluing the files together?
  • Tom Gomez
    October 26, 2011 at 5:06 pm
    Thanks for the response Ann!
    When I do “Match Sequence Settings” it does seem to pull up the precise settings from the sequence which I created. (In this case ProRes 422 1080p.) And it exports just fine.
    The problem with the export is that it’s not using the preview files. The settings for the preview files (in the sequence settings) are the exact same as the export settings. In theory, the exporter should use these preview files with no need to recompress.
    The reason why I’m doing all this in the first place is because I’ve got a lot of embedding AE compositions on the timeline. It takes a while to render them on the timeline so I can properly do my edit. It’s a huge pain to have to RE-render them when I export…
