Upon importing, video track turns up green.
Posted by Sam Mckenzie on November 4, 2012 at 8:31 amBasically, this is my problem: https://puu.sh/1mgvu
I’m using Vegas Pro 12, of course.
Whenever I import a video file (I’ve tried it with multiple files, all come up with the same result), they come out like this. The video track is green for the whole, or at least the majority, of the movie. I’ve tried importing MOV and MP4 files so far, as they’re the only kinds of file I have on my hard drive as of right now.
Is there any surefire, comprehensive method to alleviate this? I had this same problem with Vegas 11. I’m sure most other people have similar problems.
Hugo Cudd replied 7 years, 10 months ago 10 Members · 27 Replies -
Graham Bernard
November 4, 2012 at 9:49 am -
Graham Bernard
November 4, 2012 at 9:56 amGet G-Spot and MEdiaInfo, both freebies, and analyse your MP4 and MOV. Bring the results back here.
Cheers
Grzie
Steve Rhoden
November 4, 2012 at 11:24 amThats a sign of corrupted or a damaged video file.
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-832-4956 -
John Rofrano
November 4, 2012 at 3:24 pmWhere did these files come from? What codecs do they use? As Grazie said, use MediaInfo or GSpot to determine what codecs are being used. You may have to convert them to a format that Vegas can edit.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
David Prater
November 5, 2012 at 3:08 amI’m having the same problem.
This footage was shot with the front-facing camera on my iPhone 5. I’ve filmed with my iPhone for a couple years now, so I figured it was a good idea to upgrade cameras when I got my new phone. The rear camera opens fine, but the front camera footage looks like this. Every time I convert it, the video ends up lagging behind the audio.
Graham Bernard
November 5, 2012 at 5:04 am[David Prater] “The rear camera opens fine, but the front camera footage looks like this.”
Visually inspect the front lens for any breakages or anomalies or blockages? Are you shooting through a protective cover? Surf the iPhone Forums for any comparable comments regarding the Front Facing camera? Return to Apple shop?
[David Prater] “Every time I convert it, the video ends up lagging behind the audio.”
What format are you converting/rendering to?
Phil Seymour
November 5, 2012 at 5:25 amLogic switch on so we are in the realm of ducks, witches and wood.
If the rear camera works fine, then the front must be faulty. So it ain’t gunna work in any NLE. Looks like a job for Super Repairman.
Small stones float.
Windows 7 Pro64, 16GB RAM, SSD boot drive, GTX 570 Graphics, Vegas Pro 11 and VP10 just in case
David Prater
November 5, 2012 at 5:31 amThe only problem was in Sony Vegas. It played back fine on Windows Media Player and on my phone. The issue was in a QuickTime update. I rolled that back to 7.7.1 and it fixed everything.
David Prater
November 5, 2012 at 5:34 amThe front camera wasn’t faulty, just shot in a different format than the rear. A format that QuickTime couldn’t read, and therefore, for some reason, SV couldn’t either. I rolled QuickTime back to 7.7.1 and, voila, problem solved.
Graham Bernard
November 5, 2012 at 5:59 amWell, that’s a new one for me! The same iPhone shoots in 2 (are there more than 2?) User Selectable formats? What formats would they be?
Grazie
