Activity › Forums › VEGAS Pro › Upon importing, video track turns up green.
  • Mark Barton
    November 8, 2012 at 5:39 am
    Check out this on the Apple support forum:
    https://discussions.apple.com/thread/3851711?start=0&tstart=0
    They mention the front camera is optimized for Facetime and hence can have odd framerates. Use the rear camera to record 1080P video.
  • Harvey Mullin
    January 8, 2015 at 8:30 pm
    I’m having the exact same problem?? my clips never used to be green now all of them are and i don’t know why! its weird i always have glitches and problems with sony vegas 🙁 trying to edit one 5 minute video has taken me 9 months lol due to giving up for a week or two because some silly thing has happened like once the whole project corrupted and so on. please help, the clips are not corrupted because they used to be fine, in the project ive used clips from what i recorded the green clips with im not the best at computers and stuff apart from video editing and thats jolly fun seeing that i cannot fix everything that happens and gets in the way of me doing my work 🙁 thanks
  • Graham Bernard
    January 9, 2015 at 6:31 am
    [harvey mullin] ” my clips never used to be green now all of them are and i don’t know why!”
    Well, they are now. Something has changed. Hardware? OS? new drivers for GPU? Software updates? Space on your PC? If you can’t tell us what you’ve done to your PC we’ve less of a chance to assist.
    [harvey mullin] “its weird i always have glitches and problems with sony vegas 🙁 trying to edit one 5 minute video has taken me 9 months lol”
    O…K…. Could you document the changes you’ve made to you PC in those 9 months? If you can, post ’em here. If you can’t, then in all honesty, the likelihood is that we’re not going to be able to assist you.
    I have Vegas working well, with mixed media and a a fairly comprehensive set of GPU intensive Plugs.
    Grazie
  • Harvey Mullin
    January 11, 2015 at 11:54 am
    I’ve had problems with viruses recently and I’ve updated my windows updates could that have done anything?
  • Harvey Mullin
    January 23, 2015 at 3:45 pm
    The only things that have changed are viruses and thats pretty much everything. im using a dell inspiron 15r and yeah im a really good video editor but just keep getting problems with my sony vegas, if you want i can give you a screenshot of the problem?? i can see clips i imported on the timeline from before it started happening but now whatever clips i import turn green completely. Thanks
  • Colin Hay
    July 4, 2017 at 10:52 am
    Having same problem editing old IVTC footage – background goes green and when track layer above is at 0% preview flickers between the two tracks
    Seen this before and I’m pretty sure it was related to the Quicktime codec so will uninstall and install an older version to see what happens …
  • Hugo Cudd
    November 20, 2018 at 4:08 pm
    I have been looking for a solution for this. I encountered this problem when combining the recordings from 2 different devices in the same project. The resolution/frame rate etc weren’t the same. This is in sony vegas 14*. Only the video I ha just recorded and added turned up green and the video I had edited before in sony vegas was intact.
    To fix the issue I tried everything suggested in here but this seems a bit excessive to do. What worked for me and, is fast to do, is to download a video format converter (I am currently using the Handbrake software) and slightly change the properties of the video. I personally had to edit resolution and frame rate to match the values of the video I had already edited in sony vegas.
    Hopefully this helps some folks like myself who couldnt find a solution for this anywhere and who have tried the renaming of the plugin which did not work.
Page 3 of 3
