Activity Forums Adobe Premiere Pro Up/Down arrow shortcut in premiere 6.5 – what’s the equivalent in CS3?
  • Up/Down arrow shortcut in premiere 6.5 – what’s the equivalent in CS3?
    Posted by Reko Tomo on September 5, 2007 at 10:09 am
    In premiere 6.5,
    with the selected clip in timeline
    I can just move the edit line (red needle)
    by hitting up/down arrow to go to in/out point.
    But now in cs3,
    I have to define or mark
    “in/out around selection” first,
    then hit Q or W to move the needle
    to in/out point of the selected clip.
    As I’m used to do this when editing with prem6.5,
    I really hope cs3 can do the same.
    I know there’s PageUp & PageDown
    to go to the next edit, but if there are
    many cut clip below/above the layer, it will go to
    every cut where ever there is a cut clip in any layer.
    BTW, if I dont mark “in/out around selection”
    why the Q and W result is the same with
    Home and End keyboard shortcut in cs3 ?
    It moves to the beginning / end of sequence.
    Thanks in advanced.
    Reko Tomo replied 18 years, 11 months ago 2 Members · 2 Replies
  • Aanarav Sareen
    September 5, 2007 at 6:09 pm
    I haven’t used Premiere 6.x in many years, but try page up/page down to see if that helps.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Reko Tomo
    September 6, 2007 at 4:41 am
    Thank you for your reply.
    Yes, I’ve tried the PageUP/Down
    but it annoyed me, if I need to move the needle
    just to the in/out point of the selected clip
    and if I have some cut clips below the selected track,
    the needle will move to any in/out point
    of the cut clips below it first, then finally
    reach the in/out point of my selected clip.
    Anyway, thank you for your reply…:-)
