Activity Forums Apple Final Cut Pro Legacy universal codec?
  • universal codec?
    Posted by Dan Smith on June 25, 2010 at 9:20 am
    Hi Guys
    I am about to do an edit with some 7d footage. the pressure is on time-wise. Unfortunately my mac (and my pc) are pretty underpowered. I can happily edit with xdcam ex footage around 30-50 mb/s and I hear that is the way to go with 7d footage. neithe machine can cope with realtime playback of the .264s!
    My problem is that i want to edit in FCP on my mac but i want to use my PC to do some of the transcoding of the 7d files. Obviously I can’t get my pc to make apple xdcam files but I hear i can use the DVCPRO HD equivalent. I downloaded the avid codec pack to use the dv100 codec but FCP isnt happy with this… IS THERE A UNIVERSAL HD CODEC THAT A PC CAN USE THAT FCP WILL ACCEPT AS AN EDIT CODEC?
    I noticed in mpeg streamclip that there are apple dvcpro codec options but not dvcpro hd. anyone know why?
    Thanks very much (sorry if this an obvious question)
    Dan Smith replied 16 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    June 25, 2010 at 1:27 pm
    [dan smith] ” IS THERE A UNIVERSAL HD CODEC THAT A PC CAN USE THAT FCP WILL ACCEPT AS AN EDIT CODEC?”
    LOTS OF THEM. (and please stop screaming)
    but since you do not offer any info on what software that you are attempting to use for editing with it is really hard to help you.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Technology Development
    Quality Assurance Assistance
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Rafael Amador
    June 25, 2010 at 2:01 pm
    Dan,
    Converting H264 to XDCAM for editing is one of the most senseless thing you can do. Damage your footage and multiply the process time.
    Rafael
    http://www.nagavideo.com
  • Shane Ross
    June 25, 2010 at 2:19 pm
    Photo JPEG is a universal codec. But not an editable one.
    So you want to use a PC to encode the 7D footage for editing in FCP? I don’t think that is gonna work out. It is unwise to use software on other platforms for converting files to use in FCP. DVCPRO HD only comes with FCP. ProRes encoding (the PREFERRED format to convert H.264 files from the DSLRs) only comes with FCP.
    Shane
  • Dan Smith
    June 26, 2010 at 9:51 am
    Hi Gary
    Sorry, I thought my post mentioned that I would be editing in FCP.
    I have actually done what I wanted to do now. Though it seems from some responses that I may have done the wrong thing. I followed Phillip Bloom’s website and encoded my Canon 7d .264s into xdcam ex footage. Someone mentioned that this is bad, but i aim to reconform all the 264 files at the end anyway.
    my problem was that i wanted to use my PC to do some of the encoding (using mpeg streamclip) to speed things up. since i can’t export to xdcam using mpeg streamclip on a pc, i was looking for a universal codec that was equivalent to xdcam (or better) that both my pc and mac could create via mpeg streamclip that i could then use in fcp without any rendering required.
    know you of such a codec?
  • Dan Smith
    June 26, 2010 at 9:53 am
    Thanks for your response.
    It’s interesting you should say that. I am following Phillip Bloom’s instruction as he seems to be ‘the man’ when it comes to DSLRs (i may be wrong!).
    I guess i could have used pro-res. but in the end i will reconform my timeline to the original 264 files anyway so the xdcam proxies will only be an intermediary.
    Does this sound agreeable to you?
    thanks, Dan
  • Dan Smith
    June 26, 2010 at 9:57 am
    Thanks Shane, very helpful.
    I have spent nine hours encoding all my footage to xdcam – following Phillip Bloom’s website tutorial. In hindsight i guess prores would have been the better choice. Though i aim to just reconform my timeline to the .264 files at the end of the job. That should work fine (i hope).
    What you said about sticking to one system is good advice for the future. I’ll just have to upgrade my mac so he can handle more file crunching!
    All the best
    Dan
  • Dan Smith
    June 30, 2010 at 11:16 am
    Thanks Dave,
    I guess I will be sticking to the apple workflow!
    best
    Dan
