Activity Forums Apple Final Cut Pro Legacy Unable to capture ProRes, Uncompressed works fine
  • Unable to capture ProRes, Uncompressed works fine
    Posted by Andrew Dietz on March 31, 2010 at 9:10 pm
    I am unable to capture ProRes. I am using a 1080i29.97 ProRes HQ easy setup. I used an 8-bit Uncompressed setup, and it captured flawlessly.
    When capturing ProRes, it quits after a few seconds. Also, the CPU % jumps to about 270%. I know ProRes takes some processing power, but that seems high.
    I tried changing the Kona 3 from slot 2 to slot 3, and took out some Crucial RAM. Same result. I also tried using 64-bit Kona 3 firmware with no luck.
    Any help is appreciated!
    System specs:
    2×2.8Ghz Quad Core (Late 2008)
    8GB RAM
    Mac OS 10.6.2
    FCP 7.0.2
    AJA KONA 7.5
    Andrew Dietz replied 16 years, 5 months ago 7 Members · 16 Replies
  • 16 Replies
  • Andrew Dietz
    March 31, 2010 at 9:44 pm
    Also, it seems 1080psf23.98 ProRes HQ also captures fine. I tried another edit bay with different specs, and it also was not able to capture 1080i 29.97 material without located timecode breaks that didn’t exist.
  • Mark Maness
    March 31, 2010 at 9:48 pm
    Hmmmm…. That’s a new one.
    Can I ask you something? What’s your originating format and why are you trying to capture to ProRes 422 HQ?
    You are aware that ProRes 422 HQ was meant for film resolutions like 2k and 4k work. And, you do know that ProRes 422 is a 10-bit codec, right?
    I say this because so many folks out here are using this completely unnecessarily. What ever your original footage is based on, well, you can’t get any better quality than the field tapes or discs. You can’t make DV look like HDCAM and that’s what most folks think they are trying to do when using ProRes 422 HQ.
    Just some info for ya!
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Andrew Dietz
    March 31, 2010 at 9:52 pm
    We get requests for ProRes 422 HQ deliverables. I don’t have to capture everything HQ, but it’s just an easy habit for me to get into, and it’s easier when a client wants an HQ file. I have tried capturing regular ProRes also with no luck, so it’s not just HQ that is causing issues.
  • Jeremy Garchow
    March 31, 2010 at 9:54 pm
    I would completely uninstall (use the AJA uninstaller) then reinstall the drivers.
  • Mark Maness
    March 31, 2010 at 9:56 pm
    [Duke Bishop] “I have tried capturing regular ProRes also with no luck, so it’s not just HQ that is causing issues.”
    That is strange. We capture to ProRes fairly regularly without issues. I’d say reset your permissions and blow your prefs.
    Wayne Carey
    Schazam Productions
  • Andrew Dietz
    March 31, 2010 at 10:21 pm
    Jeremy – no luck. I tried ProRes LT as well. Same result. It seems FCP is locating timecode breaks that aren’t there.
  • Jeremy Garchow
    March 31, 2010 at 11:01 pm
    What deck?
  • Rich Rubasch
    March 31, 2010 at 11:40 pm
    You never said what Mac you are on. ProRes does not behave with the non-intel Mac computers.
    What system, what hard drives?
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Rich Rubasch
    March 31, 2010 at 11:41 pm
    Never mind…what hard drives are you using for capture. Did the scratch disc setting change?
    Rich Rubasch
    Tilt Media Inc.
  • Andrew Dietz
    March 31, 2010 at 11:54 pm
    Trying to catch up…
    Deck = Sony SRW-5800
    Drives – doesn’t matter as Uncompressed 8-bit captures correctly. I have tried internal, and external drives capable of 350+ MB/s.
    It seems this issue only occurs with 10-bit captures. I have tried creating the “DisableAltETTPolling.txt” file. That seemed to sort of help, but it still stops after 1 minute almost every time. I also tried removing RAM to only 2GB, but that didn’t seem to help.
    So again, this seems to affect all 10-bit captures only with a 29.97 (59.94) framerate. I’m still researching fixes/workarounds. Thanks for the suggestions, I’ll keep trying some more things.
    This thread seems like the same issue (from 2007!)
    https://forums.creativecow.net/thread/8/956695
