Activity › Forums › Apple Final Cut Pro Legacy › Unable to capture ProRes, Uncompressed works fine
  • Jeremy Garchow
    April 1, 2010 at 2:16 am
    I’d call Aja tomorrow.
  • Rafael Amador
    April 1, 2010 at 2:27 am
    [Duke Bishop] “It seems this issue only occurs with 10-bit capture”
    Why you say so?
    Have you failed with 10b Unc?
    As long as you are able to capture 8b Unc, sure is not a data-rate issue.
    The capture is held by the KONA so I don’t understand the rocketing of the CPU use.
    You have no proves that your problems comes from the KONA, so why don’t you start by optimizing the system (permissions, directories, etc) instead of looking for hardware issues?
    rafael
    http://www.nagavideo.com
  • Michael Craven
    April 1, 2010 at 2:33 am
    [Duke Bishop] “It seems this issue only occurs with 10-bit captures.”
    We previously had an issue with our Kona 3 capturing 10 bit. After much trial and error and help from AJA support, they concluded it was a faulty card and replaced it. The replacement worked fine. The original card would capture 8 bit codecs flawlessly, but would add an insane amount of noise to 10 bit captures. You might just have a defect, who knows? It happens sometimes
  • Andrew Dietz
    April 1, 2010 at 6:38 am
    I was able to confirm Uncompressed 10-bit also does not work. It’s most likely a Final Cut issue, or Kona/AJA issue. 23.98 ProRes HQ capture works fine. It’s only with 29.97 that I am having issues.
    I am having the same issue in another edit bay which I will do more testing on tomorrow. Maybe there is some deck setting that I am overlooking.
  • Ben Holmes
    April 1, 2010 at 8:15 am
    Although not ruling out a Kona card or driver issue (which you could obviously check by swapping the card for another in your facility) it also sounds like the kind of problem you get when the settings are incorrect somewhere – either incorrect capture settings, or incorrect deck settings – so what the Kona is seeing is in some way ‘non-standard’. If you’re having the exact same issue in another suite I’d take a good look at the deck – although I’m not sure how the SDI signal can be fine for Uncompressed and not for ProRes.
    Could this be as simple as a clash in the capture preset and/or Kona setup? Is the Kona detecting 29.97 from the deck? Sometimes it’s the obvious you overlook…
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Andrew Dietz
    April 9, 2010 at 7:54 pm
    I have solved this issue by changing the deck control preset to Panasonic 59.94. Even though I’m capturing from a Sony SRW-5800.
    Something about the Sony 29.97 preset it doesn’t like.
Page 2 of 2
