Activity Forums Apple Final Cut Pro Legacy Tweaked, edited Audio not the same when reopened
  • Tweaked, edited Audio not the same when reopened
    Posted by Sherwood Ball on September 15, 2006 at 5:17 am
    Does 5.1 have this problem?
    I edit my stammering interviewee, cut away so I can tighten the dialog
    cutting and save.
    When I reopen the project, the audio clips are all there visually, but
    the regions and actual content of the edited audio is all over the place.
    I take it that in 4.5 one must export these audio edited sequences
    and reimport as one audio clip.
    What a freakin’ time waster.
    This audio region used to happen in the early stages of audio recording
    in Cubase back in the days of covered wagons, ten years ago…….
    Tricks of the trade, anyone?????
    Or is this the workaround of exporting?
    Sherwood
    G5 Dual 2.5 GHz
    4G Ram OSX4.6
    Sata drives
    Final Cut Pro 4.5HD, Logic Audio 7.1
    PS CS2, AE CS2
    Sherwood Ball replied 19 years, 11 months ago 2 Members · 3 Replies
  • David Roth weiss
    September 15, 2006 at 7:42 am
    I don’t think the 86-min. doco I’m cutting would ever get finished if I had the audio problems you’ve described. I think your problems might possibly be related to pilot error.
    DRW
  • Sherwood Ball
    September 15, 2006 at 6:55 pm
    That’s certainly a help.
    Actually not correct.
    It’s happening to with editors BOTH using 4.5HD in two dif locations.
    Doh!
    How about ask more questions…………….
    G5 Dual 2.5 GHz
    4G Ram OSX4.6
    Sata drives
    PS CS2, AE CS2
  • Sherwood Ball
    September 16, 2006 at 12:04 am
    Thanx Dave,
    Very helpful.
    G5 Dual 2.5 GHz
    4G Ram OSX4.6
    Sata drives
    PS CS2, AE CS2
