Activity › Forums › Compression Techniques › Trying to increase quality on MPEG-2 for DVD, iMac 5k, compressor 3.5.3, os x yosemite
Posted by Arlin Golden on April 16, 2015 at 9:00 pmHello there. Im compressing a 92 gb master mov to mpeg-2 for dvd. I’m using the best quality 90 min codec, and Ive increased bitrate as much as i can, as well as changing frame controls to best. Ive also just done the regular best quality 90 min without changing anything and a few other configurations, but the quality on the resulting mpeg-2 is just not up to par; way too pixelated. I have room on my disc for a file 2 gb larger than the 3.1 gb mpeg-2s im getting now. Are they any ways to increase my quality to something more acceptable if im willing to increase file size as well? please help!
Craig Seeman replied 11 years, 5 months ago 3 Members · 14 Replies -
Craig Seeman
April 21, 2015 at 7:41 pmKeep in mind that DVD players have a limit to the data rate they can handle so pushing to “fill the disk” may not make for a playable DVD. You can try putting keyframes in front of transitions since that creates an i-frame… but you make no mention where the pixilation occurs. Trouble shooting suggestions are only as accurate as the information you provide. Perhaps your issue is down converting HD to Standard Def DVD but again, no information provided. The other possibility is that there are better encoders now. I wouldn’t be surprised if Compressor 4.1 could do a better job. You may want to look at Telestream Episode or Sorenson Squeeze.
Arlin Golden
April 21, 2015 at 7:46 pmHey thanks for the response! I am converting HD to SD, but I don’t see how that would result in such drastic piexelation. We were all watching DVDs for years before bluray and hd streaming hit the scene, and criterion was putting HD trasnfers onto DVDs (and still continues to do so) without any pixelation. Is there a better way to down convert to SD? right now I just take an apple prores hq master file and compress that directly to mpeg-2.
I dont understand you question about keyframes and iframes, but I can tell you the pixellation occurs in the video whenever theres a lot of motion going on; big blocky pixels.
I actually just tried the trial version of episode today to see how it performed and i saw no change in video quality.
Craig Seeman
April 21, 2015 at 8:06 pm[Arlin Golden] “We were all watching DVDs for years before bluray and hd streaming hit the scene, and criterion was putting HD trasnfers onto DVDs (and still continues to do so) without any pixelation.”
If you’re talking about commercial DVDs they’re using very high end down scalers. Down scaling can be problem.
[Arlin Golden] “Is there a better way to down convert to SD? right now I just take an apple prores hq master file and compress that directly to mpeg-2.”
In Compressor you may want to job chain and do a separate downscale. In fact you may want to do the downscale separately and check that you’re happy with the quality first.
[Arlin Golden] “I dont understand you question about keyframes and iframes, but I can tell you the pixellation occurs in the video whenever theres a lot of motion going on; big blocky pixels. “
Not enough data for the motion. Perhaps it’s a VBR peak setting. Transitions (dissolves for example) are considered extremely fast motion since every frame has changing information.
[Arlin Golden] “I actually just tried the trial version of episode today to see how it performed and i saw no change in video quality.”
All programs require user input for best quality. You have to test and tweak settings over the most difficult regions.
Arlin Golden
April 21, 2015 at 8:14 pmGreat! This is very helpful, Im loving it. So i didnt mention this but I am working for a commercial company, and these DVDs are for sale. What are these down scalers of which you speak?
and could you elaborate a little more regarding the job chain in compressor? What settings would I use for a separate downscale?
for the not enough data for motion, would using cbr instead of vbr help?
ill give the episode trial another crack with some tweaked settings and see how that goes.
thank you so much again for taking the time to respond!
Jeff Pulera
April 22, 2015 at 9:23 pmHi Arlin,
What is the length of the video? That will determine the bitrate. General rule of thumb is 560/minutes=bitrate, however most users choose not to exceed 7 or 8 max for compatibility with all players.
Jeff Pulera
Safe Harbor Computers -
Arlin Golden
April 22, 2015 at 9:27 pmIt’s just a 60 min film, so i guess keeping at 7 or 8 would be what to do (especially since builds in dvdsp that exceed 7.7 get booted).
I think I’ve determined though that my main issue is one of downscaling HD video. Ive looked through the creative cow thread on that topic and tried a lot of what was mentioned but to no avail. Is the only way to do it at a professional level to buy a downscaling box like this one? https://www.bhphotovideo.com/c/product/618348-REG/Matrox_MXO2_MINI_D_MXO2_Mini_for_Desktop.html/prm/alsVwDtl
Jeff Pulera
April 22, 2015 at 9:31 pmI’m an MXO2 Mini user and that is not what you need. You just need the correct workflow with the existing software. Not a Mac user, but in the past had seen others suggest the “right way” to get a good DVD from an HD video source using Compressor. Will search and see what I can find. It is possible 😉
Jeff Pulera
Arlin Golden
April 22, 2015 at 9:34 pmI see!
What do you use that box for if I may ask?
There must be a way, right? There are unpixelated commercial DVDs all over the place!
Craig Seeman
April 22, 2015 at 9:37 pmCompatibility depends on the quality of the DVD Player. for that reason many compressionists will keep the data rate to 6.5mbps even though the spec allows a higher data rate.
BTW there was an issue with some version of Compressor 3.x where VBR encoding resulting in pixelation. CBR set to 6 or 6.5mbps would be worth a try.
If there’s a particularly bad section with fast action, adding a Compression Marker can help as that resets the KeyFrame for the GOP where the P and B frames draw their information from.
Jeff Pulera
April 22, 2015 at 9:40 pmI work on PC with Premiere CS6, and MXO2 provides capture and playback (monitoring) from Premiere. Yes, it is capable of doing hardware scaling, but that is DURING capture or playback. It does not perform these duties within any software (exporting HD timeline video to SD format).
I searched for the HD to DVD with Compressor and find so many differing opinions…confusing as I don’t use Mac. I think part of the workflow may have been that you don’t export directly from HD to MPEG-2 DVD, rather you might export to an SD QuickTime file first, but I have no doubt there are specific settings needed for optimum results.
Jeff Pulera
