Activity Forums Adobe After Effects Trying to give a travelling ‘gleam’ to an object…
  • Trying to give a travelling ‘gleam’ to an object…
    Posted by Aza Allen on April 7, 2008 at 1:31 am
    **I have AE 7.0***
    I have a logo that I want to add a travelling gleam, like a metallic object tilting in a light.
    I have a few objects behind the logo that I don’t want affected.
    I’ve tried creating a white solid the same size as the logo and then creating a mask on that solid in the shape if the intended gleam, but everytime I create a mask on the solid, it resizes the white solid to the dimensions of my mask.
    I try to create another mask so I can keep the lower layers from being affected by my white solid ‘gleam’ layer, but that doesn’t work.
    Is there an easier way to accomplish this?
    Make sure to check out my Heroes Fan Film at http://www.myspace.com/ruesterprod
    David Bogie replied 18 years, 4 months ago 3 Members · 4 Replies
  • Darby Edelen
    April 7, 2008 at 5:38 am
    [Aza Allen] “I try to create another mask so I can keep the lower layers from being affected by my white solid ‘gleam’ layer, but that doesn’t work.
    Is there an easier way to accomplish this?”
    Put the white solid in a pre-comp with your logo. Place it above your logo and enable the ‘Preserve Transparency’ switch (it’s one of the layer switches, also accessible in the Layer menu). This will limit the sheen to only the areas where the logo is visible.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • David Bogie
    April 7, 2008 at 4:13 pm
    even easier, Generate>CC Light Sweep.
    Create additional elegance by laeyring up with Bevel Alpha so the gleam travels mostly on the bevel layer.
    bogiesan
  • Darby Edelen
    April 7, 2008 at 5:42 pm
    Sometimes easier is better… sometimes more flexibility is better. That will depend entirely on how picky you are… I guess I’m pretty picky =)
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • David Bogie
    April 7, 2008 at 10:09 pm
    That was the kicker for me.
    And that.
    bogiesan
