Trying to Capture Sony HDV 1080i/60 into Final Cut Pro 5.0.4, not working, can anyone help?
Hello. My first post here.
I’m trying to capture some b-roll footage from a Sony HDV 1080i/60 tape, into Final Cut Pro 5.0.4
I’m using my Apple PowerBook G4 15″ 1.5 GHz, 1 GB Ram. I’ve tried with a Sony FX-1 and a Sony Z1U camera, both HDV. The tape was recorded on the FX-1 camera, however it plays back fine in VCR mode on the Z1u, as well. I’ve made sure to set the settings in the Z1u camera properly, for DV firewire capture, as stated in the Z1u manual.
Both camera LCD screens will flash when i try to initiate the capture device, from the log and capture screen. however, i get an error from FCP with both cameras, stating that it can not initiate or control the capture device.
I’ve tried switching DV firewire cables. Using a 4-pin DV Firewire to 6-pin Firewire 400 cable. 4-pin DV firewire from the DV Firewire port on the SOny cameras, into 6-pin firewire 400 on my PowerBook G4.
I’ve tried using the easy setup feature in FCP, and have tried every combination of capture presets i can see that might work.
I did a search, and saw this post, below… i don’t know how this guy ended up getting his capture to work (the reply posts don’t mention how), but i have my settings the same, as well as have tried other combinations:
“Been trying to capture HDV material from SONY M15U HDV deck, shot on JVC mini DV tape (plays back fine in Sony FX 1 camera) at HDV 1080i 60. Format in easy setup is HDV, USE HDV-1080i60…when I open log and capture window, gives me an error message – “Unable to Initialize Capture Device – device is not connected (which it is!) or capture preset is not set up correctly. This might also happen if you play DV footage (which I’m not!) in an HDV device.”
My Sequence preset is HDV -1080i60, Capture preset is HDV, Device Control Preset is Sony HDV Firewire though I could’ve chosen HDV firewire, but that doesn’t seem to make a difference…using FCP 6.0.2, MAC PRO 3.0 GHz”
**NOTE – i am not using FCP 6.0.2 like he was, i am using 5.0.4, on my powerbook G4 1.5 GHz laptop.
Any ideas? Much Appreciated, thanks 🙂
Chris
