Activity › Forums › Apple Final Cut Pro Legacy › Trying to Capture Sony HDV 1080i/60 into Final Cut Pro 5.0.4, not working, can anyone help?
David Roth weiss replied 17 years, 7 months ago 5 Members · 12 Replies
Beth Goins
February 2, 2009 at 7:00 pmI’ve been having the same issue today after capturing 1080i60 with a Sony HVR-Z1U.
None of these suggestions worked, and I’ve checked and re-checked.
Trying to import into a Mac Pro 2 GHz, dual core intel xeon running FCP 6, Mac OSX 10.4.11. I finally gave up trying to capture HD and switched the iLink on and set my FCP capture settings to Firewire DV NTSC 48 kHz Anamorphic, sequence to DV NTSC 48 kHz and Device control to FireWire NTSC, because I have to use the video tomorrow at a press conference.
David Roth weiss
February 2, 2009 at 7:07 pmAre you using the 1080i60 Easy Setup to properly setup your project, or are you simply changing the settings elsewhere, such as in the capture module?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
