Activity › Forums › Adobe After Effects Expressions › Transition in into the next peak keyframe
  • Transition in into the next peak keyframe
    Posted by Anders Hattne on December 5, 2016 at 1:49 am
    I’m moving a layer using keyframes created from a waveform (percussion). Problem is, because of the “attack” of the sound the keyframes move from 0 to 100 from one frame to the other, then fade down to 0 slowly.
    What I’d like to do is the reverse really..
    So if with an expression I could check that if in 5 frames the value will be a 100, start fadeing up over 5 frames .
    is that possible at all?
    http://www.ardillamedia.com
    Anders Hattne replied 9 years, 9 months ago 2 Members · 2 Replies
  • Darby Edelen
    December 5, 2016 at 4:10 am
    The easiest thing to do might be to smooth() the incoming property. This will also have the effect of diminishing the peak, but you can counter that by scaling the result of the smooth by multiplying or using the linear() function.
    Darby Edelen
  • Anders Hattne
    December 5, 2016 at 12:55 pm
    interesting proposition!
    I’ll take a look at that..
