Activity Forums Apple Final Cut Pro Legacy Transferring FCPro4.5 Chapters via FTP between 2 Editors
  • Transferring FCPro4.5 Chapters via FTP between 2 Editors
    Posted by Sherwood Ball on September 15, 2006 at 7:00 pm
    Same project AND media on two dif drives in two dif locations
    both running same computers w/ 4.5HD.
    When chapter is copied into a new project, saved as, put in folder and
    uploaded to ftp. When downloaded to bring into my timeline, since
    there is no extension, it will only read the file as a Unix file.
    Or should I say a Eunuch file. Ouch.
    Anyone know of a dif way of saving to upload and bring into another’s
    project???????
    Thnx mucho!
    G5 Dual 2.5 GHz
    4G Ram OSX4.6
    Sata drives
    Final Cut Pro 4.5HD, Logic Audio 7.1
    PS CS2, AE CS2
    Sherwood Ball replied 19 years, 11 months ago 2 Members · 2 Replies
  • John Pale
    September 15, 2006 at 7:05 pm
    Zip the file first. This should prevent the resource forks from being stripped out.
    Control click on the file and select “create archive”. The editor who recieves the file just has to double click it and it will unzip.
  • Sherwood Ball
    September 15, 2006 at 7:14 pm
    Will give it a go. Thnx.
    G5 Dual 2.5 GHz
    4G Ram OSX4.6
    Sata drives
    PS CS2, AE CS2
