Activity › Forums › Adobe After Effects › Tracking lights to object
Posted by Bob Tanner on January 20, 2009 at 3:49 pmI created an adjustment layer and applied the CC light rays. I need the lights to stay in one position as the footage moves. I click on tracker and select the footage. It tracks the footage and apply it to the adjustment layer, but nothing happens. I’v realized that if I move the adjustment layer around the canvas with the light nothing happens, until I move it off the screen. Any ideas? Thanks!
btw, I’m new to to AE?
Bob Tanner replied 17 years, 7 months ago 3 Members · 13 Replies -
Curious Turtle
January 20, 2009 at 7:49 pmHi,
The problem is that you haven’t attached the tracker to the effect.
I would:
i) Create a “New Null Object”
ii) Track your source footage, as you did previously. This time ensure that your “target” in the motion tracker panel is the null object.
iii) Alt-click on the stopwatch next to the “Center” property on the CC Light Rays. This will open up an expressions line on the timeline. Use the pickwihp (the swirly button) to choose the Position value of your null object. This will link those values together and your effect should look like you expect.Hope that helps,
BenCurious Turtle Professional Video
Training | Editing |Support -
Bob Tanner
January 20, 2009 at 8:04 pmThanks, but what do you mean by the pickwihp (the swirly button)?
Kyle Hamrick
January 20, 2009 at 8:24 pmSounds like you might want to watch some expressions tutorials when you get the chance.
Kyle Hamrick
Editor/Motion Graphics Artist
Bob Tanner
January 20, 2009 at 9:10 pmDoesn’t seem to work. Any other way? Can’t I some how just track the light?
Kyle Hamrick
January 20, 2009 at 9:22 pmAfter reading your post more carefully…. CC Light Rays is a 2D effect. Unless done correctly, tying it to a 3D light = not working as desired. It can be done though, relatively easily, with a couple expressions. Forget where this is off the top of my head. Probably MotionScript. Did Kramer do this recently? Hmmm.
Honestly, from your initial explanation, I’m not entirely sure what’s going on in your project. Maybe if you explain what you’re trying to achieve instead of what how you’re trying to do it, we might be able to be more helpful.
Kyle Hamrick
Bob Tanner
January 20, 2009 at 9:27 pmI filmed footage in the day and created a day to night look and now I need to illuminate the street lights. I just the lights I created to stay with the street lights
Kyle Hamrick
January 20, 2009 at 9:29 pmAha.
So…. handheld footage? Is that where the tracking is coming from, I assume?
I’d suggest watching this, if you haven’t already. Will probably answer most of your questions.
https://www.videocopilot.net/tutorials/day_to_night_conversion/
Let us know if you need additional help!
Kyle Hamrick
Bob Tanner
January 20, 2009 at 9:43 pm -
Kyle Hamrick
January 20, 2009 at 10:04 pmSeeing that still helps a lot.
Does your shot have significant movement on the Z axis? If not, I’d forget about this whole 3D thing.
– Track the light on your footage.
– Apply your tracking data to a Null.
– Create a solid/adjustment layer with Light Rays/Lens Flare/etc.
Most of these effects will force you to position the center of the “light” from within the effect. You can either:
~ Precomp this layer, then parent it to your Null.
~ Use a pickwhip expression (plus some potential adjustments) to tie that effect’s center point to your Null’s position.– If necessary, do manual adjustments to the scale of your “light” to accommodate for Z-axis movement. (Also, brightness/spread/etc. if appropriate).
Does this sound like what you’re going for?
Kyle Hamrick
