Activity › Forums › Adobe After Effects › Tool for extracting only moving pixels?
Posted by Tyler Mcneill on May 15, 2024 at 9:37 amHello there,
I have a pretty weird question but maybe there already is a solution out there.
I have a plate where I only want to keep the moving elements and key out the rest. Is there a tool out there (maybe not even only in AE) that can delete pixels that have no motion and just leaves the rest?
I hope I made it clear enough to get across what I mean.
Thanks in advance for any answers!
Tom Morton replied 2 years, 3 months ago 4 Members · 5 Replies -
Mads Nybo jørgensen
May 15, 2024 at 10:52 amHey Tyler,
Of the top of my head without applying brain-cells (apology in advance if this does not work):
If I was in a rush and had to find a “quick & dirty” solution, I would freeze frame the first frame, and then apply a “difference key” + maybe finding a way of reverting or isolating that.
But there are people here who knows A.E. better than I do.
Mads -
Gregory Mcgee
May 15, 2024 at 4:55 pmHave you tried the “rotobrush” tool? If not, it’ll probably require a short tutorial. But it works great to git rid of the background. It creates a travelling matte, but you don’t have to go frame by frame and manually correct the matte on each frame. Rotobrush does it for you.
Here’s a pretty good tutorial.
Good Luck!
https://youtu.be/Tr1YIX_SZW4?<wbr>si=Ro2UbicoenGmS7H4Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tyler Mcneill
May 16, 2024 at 5:33 amHi Mads, I was thinking of difference keying first but alas there was no clean plate to work with. I thought mathematically it probably wouldn’t be a problem to determine the movement of a pixel and turn that into a matte and that there is probably already a tool out there. But thank you anyways!
Tyler Mcneill
May 16, 2024 at 5:37 amHi Gregory,
Yes that was my solution to the problem too. But alas it is a complex scene with lots of moving parts and people. Rotobrush is doing a much better job than a few years before but it’s still very time consuming. But still thank you for your quick reply!
Tom Morton
May 16, 2024 at 6:44 am+1 for Mads solution – I’ve tried to do exactly this in the past but even with a clean plate it’s difficult. Not to be pernickerty, but obviously the pixels themselves don’t “move”, they are static and just change color… so you can’t track pixel movement, you have to track changes to the pixel color… but unless you’re in highly controlled conditions – inside with no daylight leak, no moving shadow casts, static lighting etc – you’ll always have some change of color to a clean plate even if it’s a slight color cast or luma change… so then you need to add some margin of error into your difference key, which then leads to object edges having artifacts and losing clean edges…. I like the thinking and with some AI to help it out, it could be done i think…
Have you tried that magic mask in Davinci Resolve? Personally i think it does a better job then any of Adobe’s features.
