Activity Forums Adobe Encore DVD timeline is longer than asset, causing long pause between transitions
  • timeline is longer than asset, causing long pause between transitions
    Posted by Dustin on September 30, 2005 at 11:49 pm
    i have an asset that is a transition animation 3:01 in length. It contains both audio and video. This asset seems to want to turn into a timeline that is 3:12 in length. This is causing an annoying pause between my transitions. I have no idea why it wants to add 11 frames when it becomes a timeline, all my other assets that are transition animations WITHOUT audio, become timelines that are exactly the length of the asset. All of my transition assets are 3:01. ANOTHER problem im having is, when i import the asset and encode, it seems to be losing about 2 frames off the end, because I have a “flash” transition that occurs between 2 animation transitions, but the loss of the last few frames off the end cause the transition to be ugly, along with the added time due to the wierdly lengthened timeline. Needless to say, this transition, that should look fine, is pretty ugly right now, and i have no idea why. any help is greatly apreciated. thanks
    Dustin replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
