Activity › Forums › Adobe Premiere Pro › the project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type
Posted by Roger Kean on May 10, 2012 at 9:28 pmI have been working on a project using 5D footage along with R3D raw and proxy files. On my work computer its working just fine but as soon as I attempt to take it to a different machine to work on at home or in a different room I get the error
“the project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type”
I think it has something to do with the proxies since if I open a new project and import R3D raw clips they import just fine but I get errors importing the proxies. I have perian and the red codecs downloaded and installed. Any ideas?Joanna Lewandowska replied 11 years, 10 months ago 16 Members · 24 Replies -
Roger Kean
May 11, 2012 at 12:28 pmPremiere CS5, the proxies are generated in camera by the red one
Jon Barrie
May 11, 2012 at 1:09 pmIf you are crossing platforms from Mac to Win there could be issues in proxies there. Example being some QT formats that are AIC (Apple Intermediate Codec) don’t work on Win. ProRes does with the latest QT or the ProRes decoder installed but that doesn’t include others like AIC XDCAM/P2 etc.
– JB
Jon Barrie
Adobe Video Solutions Consultant ANZ
Jon’s YouTube Tutorial Page
follow Jon with twitter -
Roger Kean
May 11, 2012 at 1:42 pmAll the computers I attempt to open it on are all mac. The only difference that I can tell between them is the original computer is running Snow Leopard and the ones I try to open it on are running Lion. Any advice on how to overcome this would be helpful
Jeremy Garchow
May 11, 2012 at 2:41 pmOne potential problem is that Pr uses red native media and is having trouble reconnecting.
The other is a potential capture card conflict.
Do you have a capture card on one machine and not the other?
Roger Kean
May 11, 2012 at 4:15 pmBoth machines aren’t using any capture cards. They are just using external LaCie hard drives with firewire to edit. Ive narrowed down what I think the issue is. I think it has to do with one being snow leopard and the other running lion. Ive found that I can import the sequences individually and reorganize the whole project. So that is what Im going to do. Faster and easier than starting over. Thanks for lending a hand
Terence Kearns
May 20, 2012 at 1:39 amI’m experiencing exactly the same problem. Premiere CS6. The sequence in question is a series of PNG images. The original project was created on windows 8 and the computer attempting to open it is Lion (iMac).
Terence Kearns
May 21, 2012 at 5:01 amStill have not solved this problem.
The latest is that I have tried exporting a final cut XML file from a project on the mac (CS6) and importing that project XML file on the PC. It produced exactly the same error.
Jeremy Garchow
May 21, 2012 at 5:43 pmTerence-
Did these projects both originate in Pr CS6?
Did you use any “non native” sequences (like AJA or Blackmagic sequences) when you created them?
Jeremy
Terence Kearns
May 21, 2012 at 6:53 pmIn all cases, the sequences were originally created in ppro cs6.
I have read the entire thread at
https://forums.adobe.com/thread/478332and the conclusion was that you could fix the problem simply by using Microsoft AVI as the preview codec for all your sequences. This didn’t work for everyone, and I can confirm that this will not fix it. Some people say that the trial version (which I am using) will not have all the codecs installed. HOWEVER, I ran some experiements using only the P2 DVCPRO codecs. The proj files are only interchangeable between my iMac and my Windows PC when I select DVCpro 50 as the codec (standard def). Anything else will cause that error to manifest on the system trying to open the project file when the other system created the sequence. IE, if I add a seq on the PC, the mac won’t open it. If I add a sequence [even with the exact same spec] using the mac, then the PC won’t open it…. doesn’t matter if the codecs chosen are identical (ie. dvcproHD).
Of course all my stuff is HD, so simply using an SD codec is not acceptable. I would like to find a solution before settling on CS6 when the trial ends. I’ll be coming over from Sony Vegas if it works out. Vegas is still a better tool IMO, but it doesn’t run on the mac.
