Activity › Forums › Adobe Premiere Pro › The invisible layer is almost useless !
Robocutter replied 20 years, 7 months ago 12 Members · 35 Replies
Carlitos
January 27, 2006 at 8:04 pm“Have you ever thought about pulling your sequence into another sequence and then adding your effects in there?”
.- Man, sorry for my rudeness but
Which part of “What if You don’t want (I usually never want to) to put the desired effect(s) all over the ENTIRE sequence, just 20 clips or several groups of clips.?” do I have to explain better?
“I was hoping that it was like an adjustment layer in after effects, but it sounds like it isn’t”
.- Well, you can be absolutely sure it ISN’T.
Mark Palmos
January 28, 2006 at 12:58 am[carl] “.- Man, sorry for my rudeness but”
Dont be inauthentic Carl, you are not sorry at all.
Someone was trying to be helpful and you jump all over him.
Baz Leffler
January 28, 2006 at 1:52 amI can use it as ‘timeline notes’ between off line and on line.. place and drag it on the timeline and rename the clip as a note ‘to do’. I do this in 1.5 using black and disabling it… if someone gave me an old worn out tyre I wouldn’t say it was useless… I would hang it from a tree and use it as a childs swing….
Carlitos
January 28, 2006 at 9:37 pm“Someone was trying to be helpful and you jump all over him.”
.- No, someone didn’t understand what I want, because, apparently, that someone didn’t read clearly what I wrote and meant.
Everybody is explaining me the same old and tired Sequence trick, Like I’m not aware of it.
Well, just for everyone to know:
1.-I already know the “Sequence trick”. I’ve known that for Centuries.
2.-That’s NOT what I need nor what I want.
And I didn’t jump over him.
“Dont be inauthentic Carl, you are not sorry at all.”
.- I never insulted anyone here till the unneccesary and clearly offensive “Medication” message.
I’m complaining to ADOBE. Is my right and I’m using it.
If you don’t want to complain, and the alpha channel is enough for you, then don’t complain and be happy.
But the Alpha Channel is NOT enough for ME. I expected much more from a new feature, even more coming from the same Company that makes AFTER EFFECTS.
DO NOT try to take off the sacred right to complain from anyone else.
And I do appreciate any help.
But to hear the same “sequence thing” over and over… …that’s not helpful
Anyway, my messages are not for YOU but to Adobe.
Nobody else can help in this SPECIFIC issue but them.
And the only weapon I got is my SACRED RIGHT TO LOUDLY COMPLAIN AS A CONSUMER.
Robocutter
February 4, 2006 at 1:26 pm[Carl] “But the Alpha Channel is NOT enough for ME. I expected much more from a new feature, even more coming from the same Company that makes AFTER EFFECTS.”
they want to keep selling AE, that’s all.
