Activity Forums Adobe After Effects Text animation: grow with “bounce”
  • Text animation: grow with “bounce”
    Posted by Jeremy Allen on March 29, 2010 at 7:24 pm
    I know the basics of using the text animators with the range selectors, offsets, selector shape, etc, but I can’t quite figure this out..
    I’m trying to animate each letter in a word to start at 0% scale, grow to say 110% and then return to 100%. I’m using an offset with the Ramp Up shape, based on Characters. So I’m able to scale the letters from 0% – 100%, but I can’t figure out how to make the letters go beyond 100% and then back to 100%. You’ve seen the effect a million times and I figured this would be easily recreated with the animator.
    I played with the wiggly selector and I couldn’t quite get it to do what I wanted. Then I thought I could just add another scale property, but apparently you can only have one scale property per animator.
    Can anyone give me any pointers on this basic effect?
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
    C4D 11.5
    AE CS3
    FCP 6.0.1
    Jeremy Allen replied 16 years, 5 months ago 2 Members · 2 Replies
  • Steve Roberts
    March 29, 2010 at 7:38 pm
    This is a “but this one goes to eleven” discussion.
    Why don’t you increase point size of the letters and animate from 90% to 100%?
  • Jeremy Allen
    March 29, 2010 at 7:39 pm
    ok, so after I posted that, I figured out how to add a second animator with scale. I set up the 2nd animator just like the first one, but pushed the offset keyframes down the timeline a few frames. So now animator 1 scales up from 0% and animator 2 scales from 150% back to 100%. It seems kinda backwards to me but for some reason it works. Is this the best way to achieve this effect, or can it be done with only one animator?
    C4D 11.5
    AE CS3
    FCP 6.0.1
