Activity Forums Apple OS X Temporary use of PCI express card, now I can’t see HD in BAY #2…
  • Temporary use of PCI express card, now I can’t see HD in BAY #2…
    Posted by Phil Muri on November 14, 2009 at 6:01 pm
    Howdy Cowpokes,
    I recently needed to temporarily install a PCI Express card to use an external RAID via eSATA. On the first try, the RAID didn’t mount on the Desktop, so I downloaded a driver from the company website and it eventually mounted. Now after I removed the PCI card and reset the Expansion Slot Utility to it’s original setting, I no longer see my secondary internal drive (a 1 TB disk), located in Bay #2.
    I still see my third internal drive (2 disks, in slots 3 & 4 striped RAID-0). I tried switching the undetected drive to a different slot but still nothing. Disk Utility does not see the disk in question either. I have tried resetting the PRam and also resetting the SMC, but still no luck. Also, my computer takes twice as long to boot-up after the OS chime.
    Any ideas?
    -Phil
    Mac Pro • 10.6.2 • 2 x 3 GHz Dual-Core Intel Xeon • 5 GB 667 MHz DDR2 FD-DIMM
    Jim Mcnally replied 16 years, 9 months ago 2 Members · 3 Replies
  • Jim Mcnally
    November 15, 2009 at 2:00 am
    I read some esata drivers were causing Kernel panics in Snow Leopard. Don’t know if it’s related. Can driver be uninstalled?
    Jim McNally
    The Commercial Factory
    http://www.commercialfactory.com
  • Phil Muri
    November 15, 2009 at 6:14 am
    Hey Jim,
    Thanks for your idea of installing the driver… the only problem is: I don’t know where to look to uninstall it. It is a Tempo SATA driver.
    Any thoughts?
    -Phil
  • Jim Mcnally
    November 15, 2009 at 4:49 pm
    Look in the Hard Drive > System > Library > Extension folder and see if you can see it there. Remove it to the desktop first before deleting to see if that fixes anything.
    Jim McNally
