Activity Forums Adobe After Effects Expressions Targeting Arbitrary Layers in ExtendScript
  • Targeting Arbitrary Layers in ExtendScript
    Posted by Ralph Moreau on February 26, 2021 at 3:18 pm
    Hi all, Making a script that can allow me to ease my layers via shortcut. The problem I’m having is that I can’t seem to target a currently selected layer. I will share my code. Can anyone aid me with the logic of how to do this? I pretty much target with activeLay and numkeys. But I’ve only been successful at targeting the top layer. And a lot of efforts of changing up the target, using different methods. Please help if you can.
    var activeLay = app.project.activeItem; // mod piece for layer 1 of active layer
    //methods
    var numkeys = app.project.activeItem.layer(1).position.selectedKeys; // method that gives an array of all keyframes
    //numbers
    //keyframes
    //functiontotkeys active variables booleans\
    var posActive = false;
    var opaActive = false;
    var rotActive = false;
    var scaActive = false;
    var numAllKeys = 0; //will be the number of all keys
    var numPosKeys = new Array;
    var numRotKeys = new Array;
    var numOpaKeys = new Array;
    //~ ------------------ begin script
    functiontotalkeys(); // calling functiontotalkeys
    function functiontotalkeys() //this function will bring back all keys then call filterme
    alert("hi");
    // formula call for position
    var checkPosKey = activeLay.position.numKeys; //checking number of 'position" keys on layer 1
    alert(checkPosKey);
    //alert("this is the position key " + checkPosKey);
    if (checkPosKey >= 1) // if there are any actual position keyframes then go ahead and iterate
    for (var p = 1; p <= checkPosKey; p++)
    alert("made it");
    //alert("for loop is being called");
    var keypos = app.project.item(2).layer(2).position.keySelected(p);
    alert(keypos);
    if(keypos == true)
    alert(keypos + "HEYNOW");
    var posmod = activeLay.property("Position");// position layer module of active layer + layer 1
    var curPosKeyIn = activeLay.position.keyInTemporalEase(p)[0].influence;
    var curPosKeySp = activeLay.position.keyInTemporalEase(p)[0].speed;
    // //alert( "current influence is " + curPosKeyIn );
    var uniEasePos = new KeyframeEase( curPosKeySp ,(curPosKeyIn += 1));
    ////alert( "current influence is now " + curPosKeyIn );
    posmod.setTemporalEaseAtKey(p,[uniEasePos],[uniEasePos])
    // formula call for rotation
    var checkRotKey = activeLay.rotation.numKeys; //checking number of 'position" keys on layer 1
    //alert("this is the position key " + checkRotKey);
    if (checkRotKey >= 1) // if there are any actual position keyframes then go ahead and iterate
    for (var r = 1; r <= checkRotKey; r++)
    var keyrot = app.project.activeItem.layer(1).rotation.keySelected(r);
    if(keyrot == true)
    { var rotmod = activeLay.property("Rotation");// position layer module of active layer + layer 1
    var curRotKeyIn = activeLay.rotation.keyInTemporalEase(r)[0].influence;
    var curRotKeySp = activeLay.rotation.keyInTemporalEase(r)[0].speed;
    //alert( "current influence is " + curRotKeyIn );
    var uniEaseRot = new KeyframeEase( curRotKeySp ,(curRotKeyIn += 25));
    //alert( "current influence is now " + curRotKeyIn );
    rotmod.setTemporalEaseAtKey(r,[uniEaseRot],[uniEaseRot])
    // formula call for scale
    var checkScaKey = activeLay.scale.numKeys; //checking number of 'position" keys on layer 1
    //alert("this is the position key " + checkScaKey);
    if (checkScaKey >= 1) // if there are any actual position keyframes then go ahead and iterate
    for (var s = 1; s <= checkScaKey; s++)
    var keysca = app.project.activeItem.layer(1).scale.keySelected(s);
    if(keysca == true)
    { var scamod = activeLay.property("Scale");// position layer module of active layer + layer 1
    var curScaKeyIn = activeLay.scale.keyInTemporalEase(s)[0].influence;
    var curScaKeySp = activeLay.scale.keyInTemporalEase(s)[0].speed;
    //alert( "current influence is " + curScaKeyIn );
    var uniEaseSca = new KeyframeEase( curScaKeySp ,(curScaKeyIn += 25));
    //alert( "current influence is now " + curScaKeyIn );
    scamod.setTemporalEaseAtKey(s,[uniEaseSca,uniEaseSca,uniEaseSca],[uniEaseSca,uniEaseSca,uniEaseSca])
    var checkOpaKey = activeLay.opacity.numKeys; //checking number of 'position" keys on layer 1
    //alert("this is the position key " + checkOpaKey);
    if (checkOpaKey >= 1) // if there are any actual position keyframes then go ahead and iterate
    for (var o = 1; o <= checkOpaKey; o++)
    var keyopa = app.project.activeItem.layer(1).opacity.keySelected(o);
    if(keyopa == true)
    { var opamod = activeLay.property("Opacity");// position layer module of active layer + layer 1
    var curOpaKeyIn = activeLay.opacity.keyInTemporalEase(o)[0].influence;
    var curOpaKeySp = activeLay.opacity.keyInTemporalEase(o)[0].speed;
    //alert( "current influence is " + curOpaKeyIn );
    var uniEaseOpa = new KeyframeEase( curOpaKeySp ,(curOpaKeyIn += 25));
    //alert( "current influence is now " + curOpaKeyIn );
    opamod.setTemporalEaseAtKey(o,[uniEaseOpa],[uniEaseOpa])
    Ralph Moreau replied 5 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 26, 2021 at 3:47 pm
    Something like this should give you the first selected layer:
    var selectedLayers = app.project.activeItem.selectedLayers;
    if (selectedLayers.length > 0){
    var myLayer = selectedLayers[0];
    }else{
    alert("No layers selected.");
  • Ralph Moreau
    February 26, 2021 at 4:53 pm
    Thank you Dan!!
