Activity Forums Avid Media Composer Syncing timecode
  • Syncing timecode
    Posted by Sean Lennon on December 11, 2019 at 8:28 pm
    Hi, is there a way to show timecode in my video and my audio bins view so that i can then drag the corresponding ones into a sync bin for syncing?
    Cheers!
    S
    Sean Lennon replied 6 years, 9 months ago 3 Members · 12 Replies
  • 12 Replies
  • Sean Lewis
    December 12, 2019 at 12:44 am
    Hey Sean,
    If I’m reading your post right, it’s a simple answer. Yes – the columns you want are called “Start” and/or “End” – for start timecode, and end timecode.
  • Sean Lennon
    December 12, 2019 at 10:21 am
    Yes thank you. And can I batch sync if all audio and corresponding video are in one bin?
  • Sean Lennon
    December 12, 2019 at 10:27 am
    Also, can I sync to subclips I’ve made?
  • Sean Lewis
    December 12, 2019 at 9:56 pm
    Hey,
    Yep, if all audio and video master clips are in one bin, you can select all and ‘autosync’.
    I don’t think you can sync to a subclip. It has to be master clips. If you need to join subclips with other subclips that’s called a ‘group’.
  • Michael Phillips
    December 12, 2019 at 11:02 pm
    You can AutoSync subclips with other subclips or master clips.
    Michael
  • Sean Lennon
    December 17, 2019 at 10:24 pm
    Thank you
  • Sean Lennon
    Thank you
  • Sean Lennon
    December 17, 2019 at 10:50 pm
    Hi Michael, is there a way of doing this using timecode, as the subclip changes the timecode start time, so if i drag subclips into a bin with its corresponding audio master clips will autosync work?
    Cheers again
    Sean
  • Michael Phillips
    December 19, 2019 at 11:43 pm
    Timecode is correctly maintained in the subclip as the correct offset to its master clip.
    Michael
  • Sean Lennon
    December 20, 2019 at 12:04 am
    So as I understand you Michael, autosync see’s the subclip timecode as linked to master clip timecode and therefore will sync correctly to audio?
