Activity Forums Creative Community Conversations Switched…then switched back?
  • Richard Herd
    July 31, 2014 at 5:31 pm
    [Charlie Austin] “Nobody uses “dissolves” editing music, at least nobody I know. It’s all A/B with fine curve control…”
    Maybe they crossfade, though.
  • Oliver Peters
    July 31, 2014 at 5:45 pm
    [Richard Herd] “[Charlie Austin] “Nobody uses “dissolves” editing music, at least nobody I know. It’s all A/B with fine curve control…”
    Maybe they crossfade, though.”
    I use them if I’m editing music in a NLE.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Charlie Austin
    July 31, 2014 at 5:46 pm
    [Richard Herd] “Maybe they crossfade, though.”
    lol… if they’re feeling lazy, yes. 🙂
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Charlie Austin
    July 31, 2014 at 5:55 pm
    [Oliver Peters] “I use them if I’m editing music in a NLE.”
    I do too in 7 or Pr, because the only alternative is key framing which is a PITA. In X I use the fade handles because to me, it’s quicker and I get better results. Not that right clicking and adding a dissolve isn’t quick, but the combo of sample level positioning (for posterity… yes, I know you can do that in Pr by switching modes) and fade curves gives me more control just as quickly. At the end of the day, I just work with any app the way it works… 🙂
  • Lance Bachelder
    August 1, 2014 at 12:55 am
    I agree about native – the strength and stability of Avid was that you had to import into an Avid codec before editing – there was nothing else. Now that Redcine is so fast without having to buy a Red Rocket I just use my presets and convert to Pro Res 444 and edit that – I don’t do proxy either even though FCPX has a nice proxy workflow.
    It was at a Vegas premiere that I resolved to become an avid FCPX user.
    Lance Bachelder
    Writer, Editor, Director
    Downtown Long Beach, California
    https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1
  • Franz Bieberkopf
    August 1, 2014 at 1:02 am
    [Charlie Austin] ” Nobody uses “dissolves” editing music, at least nobody I know.”
    Charlie,
    I haven’t been following the finer points of this particular tempest in a teacup, but I use dissolves or crossfades or whatever you would have them called to edit music.
    Franz.
  • Franz Bieberkopf
    August 1, 2014 at 1:04 am
    [Charlie Austin] “… the only alternative is key framing which is a PITA.”
    Charlie,
    … try the mixer. It makes adjusting levels so intuitive and direct that you’ll forget you’re making keyframes.
    Franz.
  • Oliver Peters
    August 1, 2014 at 1:07 am
    [Franz Bieberkopf] “… try the mixer. It makes adjusting levels so intuitive and direct that you’ll forget you’re making keyframes.”
    Mixer? FCP X? LOL! Now you’re just rubbing it in 😉
    – Oliver
    Orlando, FL
  • Charlie Austin
    August 1, 2014 at 1:41 am
    [Franz Bieberkopf] “Charlie,
    I’ve tried the mixer… I used to be a mixer. Once we upgraded to automation the console essentially controlled group levels, everything else was done in the DAW, occasionally I’d set levels with the DAW faders but never crossfades. I rarely used it in FCP “classic”.
  • Charlie Austin
    August 1, 2014 at 1:47 am
    [Franz Bieberkopf] “I haven’t been following the finer points of this particular tempest in a teacup, but I use dissolves or crossfades or whatever you would have them called to edit music.”
    Of course, as do I if I’m not in X. I was actually referring to editing/mixing the actual music… making “records”. 🙂 Most engineers I know wouldn’t choose a crossfade transition, they A/B stuff and do it that way. Better results.
Page 10 of 13
