Activity › Forums › Apple Final Cut Pro Legacy › Suggestions…
  • Posted by Dave Hirschberg on May 8, 2007 at 2:13 pm
    I maybe getting lucky… I maybe getting the chance to build my FCP “Dream Machine”, but I would like some outside input to consider. Can anyone give me their “Dream Machine” set up. If money was no object, what would your ideal configuration be for the ultimate FCP station. I have to put together a wish list and I need some imput. I.E. graphics card, proccessors, ram, etc. Any ideas?
    D
    Dave Hirschberg | Motion Graphics Designer | Creative Department
    TELEMUNDO/NBC NY | 201.969.4204 | dave0@lowerthird.com | david.hirschberg@nbcuni.com
    Jerry Hofmann replied 19 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    May 8, 2007 at 2:17 pm
    Pretty simple…
    Top of the line Mac Pro (Dual Quad) loaded with RAM. At least 8GB
    Probably the X1900 Graphics card because the step up wouldn’t give much more power.
    Load each bay with a 750GB hard drive.
    AJA’s Kona 3 or Io HD.
    2X23″ Monitors (I think the 30″ is harder to work with than 2 23’s…
    FCS 2.
    More storage if necessary?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Dave Hirschberg
    May 8, 2007 at 2:43 pm
    Thank you very much. I assume that would be a good setup for AE as well?
    Dave
  • David Mcgiffert
    May 8, 2007 at 3:22 pm
    Hi Dave,
    I think that would be a good set-up for anything.
    We should all be so lucky…lol.
    If you do wind up getting it, why don’t you give us an
    update on how you like it…but I bet I know the answer…
    Have fun.
    David
  • Jerry Hofmann
    May 8, 2007 at 3:29 pm
    Absolutely. Do buy 2 gig RAM chips in case you find you need more later though… Would take a very serious job to need more than that though I think…
    Jerry
  • Raymond Tuquero
    May 8, 2007 at 4:29 pm
    I find 3 GB on a MacBook Pro … and 4 GB on the MacPro are great for editing. Not as much rendering when trying to just preview a few clips with effects. But thats my opinion. Also look into some raids.
    -Raymond-
    Houston Editor
  • Neil Ryan
    May 8, 2007 at 11:53 pm
    In addition to the responses you’ve received, take a look at this:
    https://www.apple.com/au/finalcutstudio/specs.html
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
  • Jerry Hofmann
    May 9, 2007 at 12:08 am
    Do you need to work in uncompressed HD? or would Pro Res suffice?
    Drive needs will vary according to the data rate of the video you intend to play back. 4k files take a lot more to play back than something like Pro Res 4:2:2 SD. This is cool stuff the data rates are low enough to playback on firewire drives. Faster drives would do more streams of course.
    Jerry
