Activity Forums Adobe After Effects Expressions Stop expressions expression?
  • David Conklin
    December 2, 2014 at 6:14 pm
    As far as I am aware, you cannot access the time of another comp – only the time in the comp in which the expression is written. However, if you make a new null inside your master, call it ‘timecount’, place a slider on it, name the slider ‘timecount’ and add this expression onto that slider
    time;
    You now have a marker of the current time in your master comp.
    Now, you just need to wrap all of your expressions inside your precomp in an if-else statement. There are lots of nice tools to do this, pt_ExpressEdit is one of my favorites. You can do it manually, of course, if you don’t have too many.
    var theTime = comp("masterComp").layer("timecount").effect("timecount")("Slider");
    var timeToStopExp = 10; //seconds
    if(time < timeToStopExp){
    //place your expression here.
    ] else {
    //the disabled value here:
    value;
    Change the timeToStopExp variable to whatever second you want your expressions to be turned off.
    Good luck!
    David Conklin
    Motion Designer
