Activity Forums Adobe Premiere Pro Speed change to freeze frame
  • Speed change to freeze frame
    Posted by Ron Pestes on July 11, 2013 at 3:30 am
    How do I take a clip, start at 100% speed and then slow it down to a freeze frame? I tried the speed remap tools but it only takes a clip down to 1%. Also, if I drag the keyframe halves very far apart the clip just disappears from the timeline.
    ronpesteshdvideo.com
    JVC GY-HM600
    Dell M6600
    Adobe CS6 Production Premium
    MacBook Pro
    Apple Certified Master Pro FCS 2
    Ron Pestes replied 13 years, 1 month ago 2 Members · 2 Replies
  • Ivan Myles
    July 14, 2013 at 3:58 am
    Ramp down using the time remapping effect. At the frame that you want to freeze, use the razor tool to cut the clip in two. Right-click the second clip, select Frame Hold… and choose | Hold On | In Point | OK |. Change the duration of the frozen frame by adjusting the length of the second clip in the timeline.
  • Ron Pestes
    July 14, 2013 at 7:16 pm
    Excellent, thank you!
    JVC GY-HM600
    Dell M6600
    MacBook Pro
