Activity Forums Compression Techniques Sorenson Squeeze problem
  • Sorenson Squeeze problem
    Posted by Richard Ladius on May 7, 2006 at 6:16 pm
    I need to get a recently edited show to DVD. My standard procedure for doing this has been exporting as a quicktime reference file from Avid Xpress Pro, compressing to mpv/mpg format, and then burning to disc using DVDit!. There seems to be a problem, however, with my compression stage. I use Sorenson Squeeze 3.5 for compressing, and up until now it has always worked flawlessly. Here’s the problem: About 1/8th of the way into the compression (always in the same spot on the video), sorenson stops compressing and gives me an error message that says:
    The movie file ‘”‘ cannot be found. Without this file, the movie cannot play properly
    I have two buttosn to press: Cancel or Search. I hit search and it brings up a browser for me to find the movie named ” and obvioudly that doesn’t exist. so I have to hit cancel. When I do THAT, I get:
    Unable to read the audio data. To compress this file you must turn off audio.
    So…
    Here is my compression setup:
    Elementary
    Video: MPEG-2
    3000 Kb/s
    NTSC
    29.97 fps
    Constant Bit Rate
    720×480
    I Frame Rate: 6
    PCM Audio
    1536 Kb/s
    48.000 kHz
    Stereo
    Normally I would use 6500 kb/s instead of 3000, but the show is an hour and 50 minutes long, so I’m trying to conserve space. I did try compressing on 6500 kb/s to see if it helped, but I still got the error. Does anybody know what might be going wrong here? I’m on a deadline.
    Craig Seeman replied 20 years, 4 months ago 3 Members · 6 Replies
  • Rich Rubasch
    May 7, 2006 at 6:28 pm
    These big reference files are convenient to a point…if it’s short and has few layers. Lots of things can clog the reading of a ref clip during compression. There is a ton of seeking around to put the pieces of the ref clip back together for the encoder. Usually, on a length more than 20 minutes or so you are better off ouptting the program to tape and redigitizing from the master to a single file. A reference clip from that new digitized clip will make it thgought the encoder much easier.
    A real pain in the keester when your show is amost 2 hours…that’s 2 hours to tape and 2 hours back in, but you will not have those problems with the encoder.
    Another option is to save out of AVID to a compressed codec of some sort to a self contained clip (still quite large) and run that clip through the encoder.
    If you will be making these DVDs from long program material on a regular basis, the I recommend one of the PCI card realtime encoders from Wired or other…some of the cheaper PC video cards support realtime MPEG2 encoding from your master tape. I would find one of those…chances are you will make a tape master anyway, so after you make it just send it through the encoder realtime and 2 hours later you have your MPEG2.
    But big ref clips from a long, multi-layered program are a bear.
    One last thought…have you done a mixdown of the video tracks? In the AVID I used to do a mixdown to two new tracks and then delete all the other audio, this made for a neater ref clip.
    Rich Rubasch
    Tilt Media
  • Richard Ladius
    May 7, 2006 at 11:33 pm
    I’ve already put the show to master and brought it over to a new system. I recorded into avid from a DSR-45, and then exported as quicktime reference.
    I got the video to compress fine by turning off the audio output. Now when I compress my audio file (it was exported from avid as .aif), I get the same error. I don’t know why a simple audio file (only two tracks) could create this kind of problem. Should I try exporting the audio as some other filetype? Would lowering the bitrate work?
    Thanks for the help!
  • Rich Rubasch
    May 8, 2006 at 1:27 am
    That is strange…you get the same error with the audio file? What is the audio’s sample rate and what are you encoding it to?
    Rich
  • Craig Seeman
    May 8, 2006 at 2:36 am
    Although I’m a Mac person I’ve heard of similar issues on Avid/Mac side and Squeeze. Have you tried saving as a self contained movie (not reference)?
    Is it possible you can save in a non Avid proprietary codec? On the Mac side, saving to Apple’s DV mov rather than Avid’s, has solved issues similar to this.
  • Richard Ladius
    May 8, 2006 at 3:14 am
    alright, I have it working now. I am encoding as PCM Audio at 1536 kb/s (same as before). All I did however was re-export from avid without selecting video tracks. I’m not sure what this did differently since the audio was already a seperate file, but Sorenson is compressing it perfectly now. I have the DVD made, and all is well. Thanks again for the help guys! Long live the Cow!
  • Craig Seeman
    May 8, 2006 at 3:22 am
    Maybe post a step by step for what you did that worked. I think others have bumped into similar issues with Avid export for compression so a step by step might be a great help.
    BTW, If you encode audio AC3 (192kbps for example) instead of PCM you’ll get a good but much smaller audio file, which can give you more room to push up the data rate for the video MPEG2 file.
