Sony Vegas Unmanaged exception (0xc0000005)
John Rofrano replied 8 years, 7 months ago 22 Members · 39 Replies
Jeff Mclane
August 16, 2010 at 10:04 pmHey There!
I have Sony Vegas Pro 9 and When i open up a project i previously worked on during the audio proxy rendering if i click cancel it shuts down Sony Vegas and gives me this message…
…Unmanaged exception (0xc0000005)
any advice?
Jeff
John Rofrano
August 17, 2010 at 12:46 pmif i click cancel it shuts down Sony Vegas and gives me this message…
any advice?
Don’t click cancel. Let it complete what it wants to do.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Jeff Mclane
August 26, 2010 at 2:46 amHey there…tried it, but it simply stops itself and gives the same message. what next?
jeff
John Rofrano
August 26, 2010 at 12:37 pmWhat type of audio is in your project? Proxy files are usually created with editing WMV files because Vegas doesn’t edit the audio natively. If this is the case, try converting the WMV files to another format.
~jr
Erik Thorsell
January 8, 2011 at 2:03 pmHi, My Vegas pro 9.0 stops loading on ”Creating Audio Engine”.
And today when i started my PC none of my video programs like Windows media player and VLC etc..
worked when i played up any file so do you have any tips ? it worked fine last night but now it just stops on creating audio engine…– Eric
John Rofrano
January 9, 2011 at 2:49 am[Erik Thorsell] “And today when i started my PC none of my video programs like Windows media player and VLC etc.. worked when i played up any file so do you have any tips ? it worked fine last night but now it just stops on creating audio engine…”
What changed about you PC between last night and today? Were any Window Automatic updates made? Something happened to make this error, especially since it’s affecting multiple programs. I would double check your audio settings in Windows and see if it will let you test your audio hardware.
~jr
Brian Butts
February 11, 2012 at 1:39 amI hope someone can still help me even though it has been a year since anyone has posted anything.
I have 2 videos that when I add them to a project in Sony Vegas 10.0, I get the following error as Vegas starts to build the peaks. I get the same error for both videos.
Problem Description
Application Name: Vegas Pro
Application Version: Version 10.0c (Build 469)
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:WindowsWinSxSx86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57MSVCR90.dll
Fault Address: 0x73744682
Fault Offset: 0x00024682Fault Process Details
Process Path: C:Program Files (x86)SonyVegas Pro 10.0vegas100.exe
Process Version: Version 10.0c (Build 469)
Process Description: Vegas ProAny help would be greatly appreciated in this matter.
Mike Kujbida
February 11, 2012 at 7:35 amThe last build for pro 10 was 10.0e so upgrade to that version first and see if it helps.
https://www.sonycreativesoftware.com/download/updates/vegasfamily -
Tim Brizzell
March 4, 2012 at 10:15 pmI have a trial of Sony Vegas Pro 11, and when I open it it says this,
Application Version: Version 11.0 (Build 594)
Fault Module: C:Program FilesSonyVegas Pro 11.0vegas110.exe
Fault Address: 0x00000000
Fault Offset: 0x00000000
I’ll put up a picture, the last thing it says before crashing is “Creating Windows”
