Activity Forums VEGAS Pro Sony Vegas Unmanaged exception (0xc0000005)
  • Sony Vegas Unmanaged exception (0xc0000005)
    Posted by Ariel Lynn on May 3, 2010 at 1:21 am
    I need help please!
    I just recently installed Sony Vegas Pro 9 on my laptop. I have used Vegas Pro 9 before and I reinstalled it on this laptop because my previous one crashed. It usually opens and installs without a problem. At first it opened and ran fine but now it refuses to open! It loads for a few moments then comes up with this message.
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0d (Build 1133)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Fault Address: 0x64696C00
    Fault Offset: 0x64696C00
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Process Version: Version 9.0d (Build 1133)
    Process Description: Vegas Pro
    Process Image Date: 2010-04-07 (Wed Apr 07) 17:20:52
    Please help!
    I’ve tried all the other solutions for this and none of them worked…
    ~ Reinstalling Vegas (tried this 4 or 5 times)
    ~ “Go to where you have installed sony vegas
    The is a folder called vidcap plugins
    go into that folder and ull find an “aviplug” folder and copy its aviplug.dll
    to FileIo plugins folder (search for aviplug.dll in FileIo plugins folder) and replace it with vidcap’s aviplug.dll
    it shall work for now
    cause the I/O aviplug.dll was screwed”
    ~ “control panel > cotrol panel home > system maitnence > system > advenced system settings > “Advanced” tab > “settings” under performance > data execution prevention > click add > go to the place where your sony vegas is, add it > make sure its ticked > click apply, then ok. and your done”
    None of them have worked! Any suggestions?
    John Rofrano replied 8 years, 6 months ago 22 Members · 39 Replies
  • 39 Replies
  • John Rofrano
    May 3, 2010 at 12:52 pm
    The Vegas splash screen tells you what it’s doing as it loads. What was the last thing it did? That’s probably where your problem lies.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ariel Lynn
    May 3, 2010 at 8:32 pm
    It stops at “Creating File I/O Manager”
  • John Rofrano
    May 3, 2010 at 10:57 pm
    That’s not a good sign. That’s very early on in the initialization process. I would contact Sony tech support and see if they have a way to see what’s going on at that time. If you had gotten further I’d say it might be a plug-in but you didn’t even get that far. 🙁
    ~jr
  • Ariel Lynn
    May 3, 2010 at 11:15 pm
    Alright, thanks for your time anyways. I will try and contact them.
  • Ariel Lynn
    May 4, 2010 at 7:46 pm
    Solved it! There was a problem with Quicktime so I uninstalled it and it worked fine.
    Odd…
  • John Rofrano
    May 4, 2010 at 11:11 pm
    That’s good to hear. Thanks for letting us know so we can help others.
    ~jr
  • Manuel Caro
    July 10, 2010 at 3:30 am
    Ok, Mine does the same, except it stops at “Creating audio engines”. Any help?
  • John Rofrano
    July 10, 2010 at 1:35 pm
    Most likely it’s a problem with your audio drivers. Make sure they are the latest for your audio device.
    ~jr
  • Max Jewell
    July 10, 2010 at 10:24 pm
    I’ve downloaded the free trial of vegas movie studio platinum 10. Yet it only seems to let me work for a few minutes before ceasing to respond. I’m not sure why and it is getting rather annoying. What can I do?
    Below is the message that pops up before it crashes.
    Problem Description
    Application Name: Vegas Movie Studio HD Platinum
    Application Version: Version 10.0 (Build 179)
    Fault Module: C:\Program Files\Sony\Vegas Movie Studio HD Platinum 10.0\FileIO Plug-Ins\mcplug\mcmpegin.dll
    Fault Address: 0x23213144
    Fault Offset: 0x00013144
    Process Path: C:\Program Files\Sony\Vegas Movie Studio HD Platinum 10.0\VegasMovieStudioPE100.exe
    Process Version: Version 10.0 (Build 179)
    Process Description: Vegas Movie Studio HD Platinum
    Process Image Date: 2010-04-20 (Tue Apr 20) 09:20:46
  • John Rofrano
    July 11, 2010 at 2:35 am
    What is the source of your video files? What codec do they use? It sounds like they might not be compatible with Movie Studio.
    ~jr
Page 1 of 4
