Activity Forums VEGAS Pro Sony Vegas Software & support Is CRAP, its 1 year and I can’t even un-cripple it!
  • Sony Vegas Software & support Is CRAP, its 1 year and I can’t even un-cripple it!
    Posted by Michael Najarian on February 7, 2013 at 12:13 am
    First Aftee spending a year in trying to get help a I was finally told to re-install the software using a new admin account which also failed, I lose audio, video, and have unreadable files in the past this has been the standard for this crappy software and equally crappy support.
    NOW I’ve been told that the latest technie would actually address my issue and he has also put me on the 3-4 month waitlist (it seems) its been 6 days since he reauested system information and now nothing is being done.
    Apparently the NEW Vegas support structure is to ignore the client until the project is late then leave a reply 3-4 month later telling the client to re-install, closing the inciddent w/o AND NOT rectifing the problem.
    So NOW I am left with a worthless Vegas software program, a project that cannot even be started and at least another $300 short on crippleware
    The last solution totally crippled the software, I was told to create a new account, wipe out the old software and reinstall this apparently left me without the ability to read the mpeg files AT ALL the NEW message says:
    “The Mainconcepts MPEG Plug in was not able to initialize properly. It appears that some modules are being used from a folder other than the install folder.
    Most Likely another third party application has installed mainconcept modules in the system folder. These may conflict with the plugin. Please contact Sony Support”
    Anyone have a clue how to make this POS work?
    And if not how do I proceed to sue Sony for a product that hasn’t worked since 03/2012! (and actually earlier)
    Michael Najarian replied 13 years, 5 months ago 7 Members · 22 Replies
  • 22 Replies
  • Steve Rhoden
    February 7, 2013 at 3:28 am
    Something odd/strange is simply going on with your system Michael.
    Something you have installed, software/hardware, is probably
    coming into conflict with Vegas.
    Vegas support is less than perfect yes, but Vegas is not Crap, trust
    me on that, Something in your system is causing your issue.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Gabriel Solomon
    February 7, 2013 at 4:59 am
    I will agree with Steve. Vegas is a great program. Although it has its flaws, I have had good experiences with Sony Support and this forum is great. I think you may have a problem with the actual hardware you are using. Good Luck
    Gabriel Solomon
    LifeCapture Images
    http://www.lifecaptureimages.com
  • Michael Najarian
    February 7, 2013 at 7:49 am
    A few years ago I would have said the same, Software Support is NOT what it use to be, SONY is also a far cry from what it also was.
    I’ve had this package for over a year and its one problem after another, I am not a big production person but when I need my software to work its GOT to be there!
    And this DOES NOT excuse support for letting issues after issue accumulate w/o a resolution for over a year and closing the problems w/o solutions.
    My hardwar works fine, I have several other competitors products running fine or at the bery least adequate AND Vegas ran fine for over a year (older version), I’ve also re-installed the os 3 times over and with a fresh install vegas still has issues, Tell me you never imported a file that says simply “error …. ” without a code or explanation, or that your audio or video failed to load, I NOW know dozens of people with these type of errors…
    Version 11 solidified the failings of Vegas in my opinion, in fact it was pretty bad with version 10 as well.
    So any solution other than re-install or its a hardware problem, neither of these offer solutions OR explanations why the same hardware worked 2 years ago, nor why 3 fresh installs from OS to vegas also failed to correct all the problems.
  • Jay Allen
    February 7, 2013 at 3:03 pm
    I feel your pain, and im in the same boat. Its funny how all our other programs work including older versions of vegas and all we hear is re- install. Vegas 12 is just not ready to put in front of a client.
  • Michael Najarian
    February 7, 2013 at 5:32 pm
    I Will be honest. When it worked in the past it was by far the BEST product in the industry.
    I am finding as with other software products that had a long history of excellence that when you build a near perfect product that really needs little or no modification that the generation responsible for the Magic retires or is canned and the new people and company no longer care, they just want to milk the money they can get out of its dieing carcus
    I see this in Vegas for the last couple years, Support simple does not give a %#^$ and really can’t fix anything, the firt error message after the install simply said error…. The next provided an unaddressable explanation – the signs of crippleware – And I paid thousands of dollars for the Vegas series products to get this kind of treatment.
    I should have torrented it like I will suggest to my clients should they want to stay with the product.
  • Mike Kujbida
    February 9, 2013 at 1:59 pm
    [TJ McCormick] “…i’m not including ANYTHING except .mxf players and converters…”
    TJ, I’m really curious as to what .mxf players and converters you’re using as I deal with post houses who prefer ProRes files which of course I can’t give them 🙁
    Thanks!!
  • Michael Najarian
    February 9, 2013 at 10:35 pm
    I noticed something similar with a window sto windows upgrade, I went from a legacy 3gh vaio to a powerspec with crossfire 4670’s (which the vegas people SAID would be useful in rencering BEFORE I bought Vegas 11).
    The issue at hand is that the software does not do well in a linear fashion, faster CPU in theory should render faster, GPUS should improve life, but I noticed moreso then not that the CPU on the legacy system was thrashing but getting faster results then the same version 64 bit on a core i7 with 2 x GPU’s.
    So you need to experiment to get JUST the right mix of hardware and software to make it run.
  • Michael Najarian
    February 9, 2013 at 10:46 pm
    Since this message the Begas people responded 6 days thats a record!
    And What did they say – – – – – Re-Install.
    So here is a procedure to Blow away ALL your sony Vegas stuff and start clean:
    https://www.custcenter.com/app/answers/detail/a_id/4844/kw/clean.
    The previous re-install instructions both left older copies of vegas and plug-ins etc… I wiped out everything Vegas, I simply needed to get the project along.
    Summation: Vegas has issues with older version of VEGAS, it has issue s with .net and probably c redist libs.
    I havn’t address the 1/2 dozen other issues I’ve had in the past yet since I need to get this current project done but at this time I consider Vegas no longer crippleware but rather FU#&$D up Warez.
    By the way I recommend looking at above links home directory – it has some interesting fixes and info.
    I am now trying to recover Plug-in and addons that were lost in this last fiasco.
  • Michael Najarian
    February 9, 2013 at 10:54 pm
    Once upon a time when Computers ran 1 processor and I had 4 machines each dedicated to ONE major software package a problem was clear and obvious, either the OS or The APP.
    Today programs have to live with neghbors, LOTS of neghbors, they should give a user understandable error message like “Neigbor one has locked this library up and I cannot run” or “error xxxxx, please refer to your manual for details”.
    Unfortunatley errors now say “error cannot open file”, or just “error”, Software support is flimsey even if you call one a year TOPS.
    I read about your MAC issue and find that obscene, software designed to run optimally on teh mac does better in a windows Emulation mode!?!, sounds like a begas problem, very odd…
    But re-installation of teh OS everytime ONE app files on these new 7 core monsters means losing a dozen of other apps with it, I cannot afford to have the weakest link on the system be VEGAS, and the solution be re-instal the OS.
  • Michael Najarian
    February 9, 2013 at 11:02 pm
    I did not give up on symantec Ghost when it did not run for a full year without issues, the reason was simple – they tried to help. Unfortunately in the end a full OS restore Was the ONLY way to get that app back!, I MEAN THE ONLY WAY.
    Its not likely that I will give up on Vegas, they do actually have a help line and I understandable only called once when I went ballistic because the software re-install could not read ANY FILES, PURE CRIPPLEWARE, but with a radical wipe out of ALL VEGAS Software I was able to function again (waiting to see for sure but it seems okay).
    Vegas IS the best Program in the market, when it works. When it doesn’t its issues are agrivating beyond words since it usually consumes allot of time and effort before it blows up in your face.
