Activity › Forums › VEGAS Pro › Sony Vegas Pro 12.770 freezes when I import a previously rendered .mp4 file
  • Sony Vegas Pro 12.770 freezes when I import a previously rendered .mp4 file
    Posted by Cedric Divang on January 15, 2014 at 4:16 pm
    Hello, Sony vegas Pro 12 build 770 crashes when I import a previously rendered .MP4 file and drop it to the video/audio tracks. It becomes unresponsive and all I can do is kill the app. I can easily reproduce this bug.
    You can download the video that freezes Vegas here : https://www.lehit.com/temp/svp12.770.freeze.zip
    The video that freezes was rendered using the very same software with this settings :
    Codec : MainConcept AVC/AAC (*.mp4)
    Frame Size : HDV 1080 (1440×1080) – Don’t allow source to adjust frame size
    Profile : High
    Frame rate : 25,000 (PAL) – Don’t allow source to adjust frame rate
    Field order : Upper field first
    Pixel aspect ratio : 1,333
    Number of reference frames : 2 (default) – Use deblocking filter
    Variable bit rate – 2 Pass
    – Maximum bps : 20 000 000
    – Average bps : 10 000 000
    Number of slices : 4 (default)
    Encode mode : Render using OpenCL if available
    Enable progressive download
    And here is the result file’s nfo that freezes Sony Vegas even though I can read it without any problem on any video player (WMP, VLC, etc.) :
    ________________________________________
    General
    Complete name : I:\TEMP\VEGAS\Open d’Australie 2014, 64F, Rafael Nadal vs Bernard Tomic, rated.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 93.2 MiB
    Duration : 1mn 17s
    Overall bit rate mode : Variable
    Overall bit rate : 10.1 Mbps
    Encoded date : UTC 2014-01-15 00:04:25
    Tagged date : UTC 2014-01-15 00:04:25
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=4, N=15
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1mn 17s
    Bit rate mode : Variable
    Bit rate : 10.0 Mbps
    Maximum bit rate : 20.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 4:3
    Original display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 50.000 fps
    Original frame rate : 25.000 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.129
    Stream size : 91.9 MiB (99%)
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 1mn 17s
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel count : channel0
    Original Channel count : 2 channels
    Channel positions : Front: L R
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 1.18 MiB (1%)
    Language : English
    Thanks for yout help !
    Jay Thompson replied 11 years ago 7 Members · 39 Replies
  • 39 Replies
  • Stephen Mann
    January 15, 2014 at 4:38 pm
    Try taking the accent character out of the filename: “d’Australie”.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Graham Bernard
    January 15, 2014 at 5:14 pm
    Steve, I used the exact same title on a test MP4 that was rendered out of Vegas, and Vegas opens it. So I don’t think it’s that? You do mean the high-comma, as in – d’ – yes? Well here that’s not stopping it from opening.
    Grazie
  • Cedric Divang
    January 15, 2014 at 5:35 pm
    Yes it freezes with of without it
  • Cedric Divang
    January 15, 2014 at 5:50 pm
    Stephen, thanks for your reply. No the character is not a problem.
    I have added a link to the video on my original post. If you or anyone else could download it and tell me if it freezes their copy of Vegas too, it would be useful :
  • Graham Bernard
    January 15, 2014 at 6:21 pm
    The frame rate has doubled in the Media Info. Any reason?
    Grazie
  • Stephen Mann
    Sorry, it loads here just fine.
    How is your free disk space on the project and the temp drives?
    Steve Mann
    http://www.mmdv.com
  • Graham Bernard
    January 15, 2014 at 6:30 pm
    Good question Steve.
    G
  • Cedric Divang
    January 15, 2014 at 6:48 pm
    After importing the video, have you tried dropping it to the video/audio tracks ? Importing the video is not a problem, it’s when you try to edit it (split sections, etc.) or even rendering it that it freezes. Thanks again for your help, it’s really appreciated 🙂
  • Cedric Divang
    January 15, 2014 at 6:50 pm
    300GB free space.
  • Cedric Divang
    January 15, 2014 at 7:09 pm
    Good point Grazie. I have no idea, I always render using “25,000 (PAL)” in the rendering menu :-/
Page 1 of 4
