Activity › Forums › VEGAS Pro › Sony Vegas Pro 12: After render problem (videos sometimes get choppy)
Posted by Georg Berruda on May 27, 2013 at 2:09 pmHello.
I have a problem with sony vegas pro 12, I have edited a video that is like 6-min long with some fade effects, text over video ecc. and the problem is that after the rendering, some part of the video get’s choppy like at min 6 of the video the quality go very bad for some seconds (i can see big pixel) and then go back to normal. I have tried to re-render the project, but everytime in the same point of the video i get that problem. I have tried to re-install vegas but that didn’t help.Vegas do that problem with every project that i do! I have a good pc, with 8 gb ram and a good graphic card that can handle games like battlefield3 at medium quality without lag. So i can’t understand what to do, i need a help please!
Chuck Thomas replied 10 years, 10 months ago 11 Members · 20 Replies -
John Rofrano
May 27, 2013 at 3:24 pmTry disabling the GPU Acceleration under Options | Preferences | Video. I had a similar problem and disabling the timeline GPU playback support fixed it.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Georg Berruda
May 27, 2013 at 6:14 pmHi John, Thanks for the reply, but I’ve already tried your solution because Vegas won’t render my videos with GPU acceleration, it get stuck every time it encounter fade or cuts. So i render everytime with that option off. I have tried other programs like Camtasia Studio 9 and it render videos without problems. I render in MP4 1280 x 720. 29,98 fps with “best” render quality active.
I need that risolution for internet videos.
Thanks for reading,
Jeorg.
John Rofrano
May 27, 2013 at 9:11 pmSo when you say that it gets “choppy” are you referring to the frame rate stuttering, or the actual video picture breaks up? If the image is breaking up then perhaps your average bit rate is set to low. Are you rendering and a Constant Bit Rate (CBR) or Variable Bit rate (VBR)?
~jr
Georg Berruda
May 28, 2013 at 10:39 amHi John,
Thank you for the answer!I render my videos using the template Internet HD 720p at VBR with Maximum set to 16.000.000 and Average: 8.000.000
And with Choppy i mean that the actual image breaks up (the strage thing is that if i re-render the project is gonna break up in the same point everytime, in other videos too), like the quality go really bad for some seconds.Maybe have i to try CBR?
I think im gonna try to change template too.
Thank you for reading.
Jeorg.
John Rofrano
May 29, 2013 at 10:02 am[Georg Berruda] “And with Choppy i mean that the actual image breaks up (the strage thing is that if i re-render the project is gonna break up in the same point everytime, in other videos too), like the quality go really bad for some seconds.”
It sounds like at that point in your video there aren’t enough bits to accurately represent the image. Try checking the Two-Pass option and see if that helps.
[Georg Berruda] “Maybe have i to try CBR?”
No, this will make the entire video you more bits just to make that one scene happy. VBR is still the right way to render. You might have to raise the maximum bit-rate a little but start by using the two-pass option.
[Georg Berruda] “I think im gonna try to change template too.”
Try the Sony AVC encoder. Sometimes MainConcept does the best job and sometimes Sony does the best job. It all depends on the program content.
~jr
Alex Sharp
August 10, 2013 at 5:07 amANSWER
Hey guys, this is the best way to get rid of choppy preview/render everything. I had exactly that problem, and it really made it mad.
Load up sony vegas go to options>preferences>video>GPU acceleration of video processing>off
And close vegas, open it again and it works!!!
There you go! Anyways that’s the ONLY way I found it works. If it did please subscribe to my youtube channel, its name is lolOptixHD and like my videos!!
Thanks 🙂
Tylor Zohr
October 31, 2013 at 4:21 amTHANK YOU!!!!!!!!!!!!!!!! I made this account just so I could say thanks.
Georg Berruda
October 31, 2013 at 10:19 amHi again, and thanks for all the replies.
I have already tried to set GPU acceleration of video processing>off
But it didn’t work. So now i have more details on my problem: The video get this problem just in the dark images. for exemple: all the video have images of green hills then it comes a black backround with some white text over it, and HERE -> Choppy and bad quality. Then back to green hills -> Normal. The only solution i have found is change encoder.I switched MainConcept to Sony AVC, And that worked.Thank you all again!
Georg Berruda
John Rofrano
October 31, 2013 at 12:34 pmYea, whenever you see stuttering or glitches in your playback or renders, always check the GPU option to see if turning it off helps.
~jr
