Activity Forums VEGAS Pro Sony Vegas Opening Crash
  • Sony Vegas Opening Crash
    Posted by Patrick Bryan on September 8, 2015 at 9:09 pm
    Hello
    I’ve been working on a project in sony vegas and every time I open it, it works for a few seconds and then I get this error
    Extra Information
    File: C:\Users\Patrick\AppData\Local\Sony\Vegas Pro\12.0\dx_video_grovel_x64.log
    File: C:\Users\Patrick\AppData\Local\Sony\Vegas Pro\12.0\svfx_video_grovel_x64.log
    File: C:\Users\Patrick\AppData\Local\Sony\Vegas Pro\12.0\ocio_x64.log
    File: C:\Users\Patrick\AppData\Local\Sony\Vegas Pro\12.0\dx_grovel_x64.log
    File: C:\Users\Patrick\AppData\Local\Sony\Vegas Pro\12.0\vst_grovel.log
    File: C:\Users\Patrick\AppData\Local\Sony\Vegas Pro\12.0\gpu_video_x64.log
    File: C:\Users\Patrick\Videos\sly 4 after.veg
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 12.0 (Build 770) 64-bit
    Problem: Unmanaged Exception (0xccccfffe)
    Fault Module: C:\WINDOWS\system32\KERNELBASE.dll
    Fault Address: 0x00007FF8B5248B9C
    Fault Offset: 0x0000000000008B9C
    Fault Process Details
    Process Path: C:\Program Files\Sony OLD\Vegas Pro 12.0\vegas120.exe
    Process Version: Version 12.0 (Build 770) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2013-11-20 (Wed Nov 20) 20:45:00
    Can someone please help me out?
    Patrick Bryan replied 10 years, 12 months ago 5 Members · 102 Replies
  • 102 Replies
  • Bob Peterson
    September 8, 2015 at 11:50 pm
    I would try renaming the veg file in Windows. Then replace it with the veg backup file. If that doesn’t work, search the forum for “unmanaged exception”. Steve Mann used to post the procedure for dealing with an unmanaged exception fairly frequently.
  • Patrick Bryan
    September 9, 2015 at 12:01 am
    Yep, nothing changed when I did so. And when I searched in here there was a lot of results. is there a forum in particular that can help?
  • Wayne Waag
    September 9, 2015 at 12:28 am
    A few questions. Does it only crash on this one particular project or crash in general? Have you done a reset of Vegas setting it back to all its defaults? (Hold down Ctrl-shift and then double-click on Vegas icon. You’ll get a box asking you if you want to reset.). Have you disabled your GPU? Open go to video preferences and disable and restart. Might be worth a try. If it only does this on the one project, you might open another instance of Vegas and begin copying assets from the “bad” project to the new project? As always, screen shots of your timeline would be useful.
    wwaag
    wwaag
  • Patrick Bryan
    September 9, 2015 at 12:36 am
    It seems to crash in general. I though the veg file was corrupt so I redited the video and it was fine, but the next day I open it and now it keeps crashing over and over, even when I leave it alone. I did try unintsalling and reinstalling vegas but I dont know how to reset vegas at all or how to disable GPU
    This is what it looked like when It crashed
    this is what the timeline looks like
  • Wayne Waag
    September 9, 2015 at 1:05 am
    Reread my post. It gives exact instructions.
    Go to options. Select Preferences. Select the Video Tab. The 3rd line says GPU acceleration of video processing. Just select Off.
    wwaag
  • Patrick Bryan
    September 9, 2015 at 1:09 am
    should I check the box?
  • Patrick Bryan
    September 9, 2015 at 1:29 am
    I also have some new blue effects installed so would those have an effect on this?
  • Wayne Waag
    September 9, 2015 at 1:52 am
    I’d say yes. If you’ve already un-installed and then re-installed Vegas this may not have an effect anyway.
    I don’t have any installed, so I really can’t tell you except that there have been quite a few threads both here and on the Sony Vegas Pro forum of members complaining of problems with New Blue. I’d say un-install and see if it makes a difference. You can always re-install.
    wwaag
  • Graham Bernard
    September 9, 2015 at 3:06 am
    What I can see is that your Project doesn’t match your media. Why? I try and get my Project match the majority of my Media.
    I also think you have reached some kind of memory choke. Here I see your Timeline images are not redrawn:
    What size/MBs of stills or whatever they are, are you using? TIFFs? For sure “something” is choking Vegas, added to which your settings could benefit from being reviewed too.
    Grazie
  • Patrick Bryan
    September 9, 2015 at 3:12 pm
    I mean my project settings have been like this for years so I don’t think that’s the case, so I’m guessing it’s either a memory choke, a file in sony vegas, or the new blue effects I have. What would be the best steps of action from here? If it’s memory my PC is currently having 1280MB of Ram max is 8GB and the recommend it says is 4578. What settings should I chnage to?
Page 1 of 11
