Activity › Forums › VEGAS Pro › Sony Vegas Effects windown over laping
  • Sony Vegas Effects windown over laping
    Posted by Amith Devadiga on August 18, 2012 at 9:20 am
    Hello everyone.
    i have been using sony vegas 10 since last 3 years, now i am facing problem while giving Video effects. i am not able to see full properties of video effects / transitions.
    Please find attached screens..
    Help Needed urgent..
    Matt Crowley replied 14 years, 1 month ago 5 Members · 15 Replies
  • 15 Replies
  • Amith Devadiga
    August 18, 2012 at 9:23 am
  • Nigel O’neill
    August 18, 2012 at 12:58 pm
    This occurs to me occasionally in Vegas, but I usually do not see anything in the properties. You are seeing half a screen. A restart of Vegas usually restores normality.
  • Amith Devadiga
    August 18, 2012 at 1:23 pm
    Hi Neill,
    I tried restarting Vegas. still same problem. hope someone solve this ..
    thanks in advance..
  • Steve Rhoden
    August 18, 2012 at 8:15 pm
    Try resetting Vegas by holding down ctrl and shift
    while launching it, this will place things back to its
    factory default settings…Hopefully this will work for you.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Nigel O’neill
    August 18, 2012 at 11:06 pm
    Sorry Amith, i meant reinstall Vegas, but try what Steve suggests first.
  • John Rofrano
    August 19, 2012 at 12:15 am
    Have you set the DPI on your Windows fonts to anything other than the default? Messing with Windows fonts and DPI is the usual cause for windows being cut off like that.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    August 19, 2012 at 11:07 am
    Also a good point…
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Amith Devadiga
    August 19, 2012 at 3:38 pm
    Hello Steve & John
    i tried restore factory setting option it didnt work for me 🙁
    i didnt change DPI of my Windows fonts, is any option to check ? if its changed ?..
    i am using winXp Sp3, 4 GB Ram.
  • John Rofrano
    August 19, 2012 at 4:26 pm
    [Amith Devadiga] “i didnt change DPI of my Windows fonts, is any option to check ? if its changed ?.. “
    Right-click on your desktop and select Properties. Then go to the Settings tab and press the Advanced button. The DPI setting is on the General tab. It should be set to Normal size (96 DPI)
    ~jr
  • Amith Devadiga
    August 19, 2012 at 4:36 pm
    hello John
    i just checked its in default 96 DPI
