Sony Vegas Effects windown over laping
Matt Crowley replied 14 years, 1 month ago 5 Members · 15 Replies
John Rofrano
August 19, 2012 at 4:38 pmIt looks like it might be a display driver issue. Try updating to the latest drivers for your graphics card and see if that helps. Otherwise, I can’t imagine what it might be.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Steve Rhoden
August 19, 2012 at 6:21 pmCant imagine what else could be causing your issue!…
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Amith Devadiga
August 21, 2012 at 9:45 amI have tried everything but no luck 🙁
last option to reinstall vegas…
hope….. it works..
Amith Devadiga
August 21, 2012 at 12:11 pm -
Matt Crowley
August 22, 2012 at 6:58 pmIt could be a font corruption issue. Normally the font used for menu and dialog box text is Tahoma or similar, but it looks like you have the System font instead. Try resetting your Windows theme or manually selecting Tahoma as the font for menus, message boxes etc.
To check if the Tahoma font is corrupt, try using it in Word, or Vegas or any application. If you can’t use it correctly, then you may need to refresh your copy of the font file – the fonts can be copied across from another working Windows PC.
