Activity Forums VEGAS Pro Sony Vegas Crashing When Adding Media, amdocl64.dll problem.
  • Sony Vegas Crashing When Adding Media, amdocl64.dll problem.
    Posted by Jake Smith on July 25, 2012 at 7:14 am
    Getting this error when trying to add text media or fix media imported. Tried updating display drivers and still not working..
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 683) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:windowssystem32amdocl64.dll
    Fault Address: 0x000007FEE7F6F413
    Fault Offset: 0x000000000004F413
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 11.0vegas110.exe
    Process Version: Version 11.0 (Build 683) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2012-04-27 (Fri Apr 27) 21:43:00
    Jeff Schroeder replied 14 years ago 2 Members · 3 Replies
  • Jeff Schroeder
    July 25, 2012 at 2:49 pm
    Jake,
    According to the web the amdocl64. dll is AMD Accelerated Parallel Processing OpenCL 1.1 Runtime
    This is for your video card.
    If you are out of date I would upgrade to the latest version. If you are current then I would back down one version, maybe two, and see if that helps.
    Keep us posted,
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Jake Smith
    July 25, 2012 at 7:32 pm
    Thanks for the reply, do you have any idea on how to downgrade? I’m not the brightest bulb in the box and if I Google the topic I’d probably screw something up.
  • Jeff Schroeder
    July 25, 2012 at 8:40 pm
    Go to the support site for your video card and see if they have previous releases of their video card driver that you can download. If they have a forum you can ask there too.
    Jeff
