Sony Vegas .Avi Issues! Please Assist!
Posted by Mike Darman on February 14, 2014 at 3:58 pmHello all,
I record videos on my PC with the full version of Bandicam, which saves the video as a .avi
I’ve tried to import the media but it keeps coming up with an error!
I’ve been searching endlessly, codecs dont work, and I need a solution.
Could someone please assist me?John Rofrano replied 10 years, 8 months ago 9 Members · 24 Replies -
Scott Simpson
February 14, 2014 at 4:18 pmI hope you haven’t taken the desperate but misguided step of installing one of those “codec packs.”
Grab MediaInfo and look at what codec your file uses. Install *that* codec.
Looking at the Bandicam website, I see you can download the codec they recommend: https://www.bandicam.com/codec/
Seems to suggest it records in Mpeg1 or Mjpeg.
Have you tried this already?
Radio guy in a TV world. Bigasssuperstar.com -
Graham Bernard
February 14, 2014 at 4:18 pmSTOP!
First off use MediaInfo to determine just WHAT is inside your AVI. It is a free downloadable interrogation s/w: Download MediaInfo
Get back here and tell us.
Cheers
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Mike Darman
February 14, 2014 at 4:36 pmI did stupidly do the “K” pack. I uninstalled it though. I actually didn’t check the bandicam website to be honest. But here is what Mediainfo says:
General
Complete name : C:\Users\Michael Marrero\Desktop\Graphics and Graphic Programs\bandicam 2014-02-13 16-51-02-357.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 436 MiB
Duration : 20mn 12s
Overall bit rate : 3 018 Kbps
Writing application : BandiAviMuxer 1.0Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 20mn 12s
Bit rate : 2 847 Kbps
Width : 1 008 pixels
Height : 480 pixels
Display aspect ratio : 2.100
Frame rate : 15.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.392
Stream size : 412 MiB (94%)Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 50
Duration : 20mn 12s
Bit rate mode : Constant
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 23.1 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.36 video frame)
Interleave, preload duration : 72 ms -
Mike Darman
February 14, 2014 at 4:47 pmHere is what I was told about the video from MediaInfo
General
Format : AVI
File size : 436 MiB
Duration : 20mn 12s
Codec ID : XVID
Duration : 20mn 12s
Height : 480 pixels
Color space : YUV
Bit depth : 8 bits
Format : MPEG Audio
Codec ID : 50
Duration : 20mn 12s
Bit rate : 160 Kbps
Scott Simpson
February 14, 2014 at 5:12 pmSo, you have xvid video and mp2 audio.
I remember having trouble with xvid showing up when I was using Vegas 10 or 11, 32-bit version.
I think you might have success by installing ffdshow: https://sourceforge.net/projects/ffdshow/
It’s a video-for-windows codec program. IIRC, that solved my xvid woes.
Having said that, xvid is not an ideal format to record to if you’re planning to edit it later.
Mike Darman
February 14, 2014 at 5:13 pmThank you! My recorder actually has a setting to record on for Sony Vegas specifically. I will do that next time. I am running Sony Vegas 12 Pro. I will get back to you and see if ffdshow works.
Graham Bernard
February 14, 2014 at 5:18 pmNasty…..
Can you play it on anything? VLC? I’m guessing it’s that XVID stuff that is throwing Vegas into a spin. The nearest I’ve got to this is this one:
XviD ISO MPEG-4 xvid.org (open source)
Can you even SETUP vegas in the project settings with those parameters? 15fps?
Try zapping it through G-Spot to see if you have the required CODECS installed. I can see a DI needing to be employed – sorry….
Grazie
Mike Darman
February 14, 2014 at 5:20 pmSo I went to the link, ran it, and clicked install. I figure thats all that is needed to be done. Then I opened up SV again and tried to import the footage but it still says It cannot be opened. Although I can avoid this in the future, I do not want to scrap this episode. So I need to get this fixed temporarily.
Scott Simpson
February 14, 2014 at 5:29 pmJust installing this and that won’t help. You’ll need to go in and make sure it’s configured, too.
