Sony Vegas .Avi Issues! Please Assist!
John Rofrano replied 10 years, 8 months ago 9 Members · 24 Replies
Scott Simpson
February 14, 2014 at 6:21 pmHere’s one guide of many available: https://www.afterdawn.com/guides/archive/ffdshow_install_configure_page_3.cfm
Basically you’re setting it up to say “Computer, when Windows wants to play an xvid file, I want you to feed push the encoded video to ffdshow and trust that ffdshow will spit out a decoded video on the other end.”
Right now, Vegas is looking for a vfw filter for xvid and finding none, so you’re probably getting a blank video, yes?
Radio guy in a TV world. Bigasssuperstar.com -
Scott Simpson
February 14, 2014 at 6:25 pmSo, you’re dragging a file with an .avi extension from, say, Explorer, onto the timeline, and what happens when you let go?
Scott Simpson
February 14, 2014 at 6:48 pmWell, if you’ve installed and configured ffdshow, closed and opened Vegas, rebooted and tried again, I’m out of ideas for you to try with that file.
Mike Darman
February 14, 2014 at 6:50 pmIm still trying to configure ffdshow. Im so stumped, I have no idea how to do this or what I should do. When it comes to this kinda thing, you can call me illiterate lol.
John Rofrano
February 14, 2014 at 10:26 pmYou could try using a program like AviDemux 2.5 to convert the video to M-JPEG with PCM audio which will edit fine with Vegas Pro. Make sure you use the 2.5 version of Avidemux and NOT the newer 2.6.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Rogerio De souza
February 16, 2014 at 10:35 amHello, you will not be able to import the audio of that video avi properly for Sony Vegas because it is MP2 audio (MPEG Layer 2) and Sony Vegas does not support this type of audio in .avi files .
You’ll even be able to import the video from the Xvid codec installed on your Windows but not audio .
If you want to install the Xvid codec to test, install it according to your Sony Vegas, or if your Vegas is 32 bits install the 32-bit codec (if its still being Windows 64-bit), and if your Vegas is 64-bit install the 64-bit codec … the link below you can download, there is an installer of over 10MB and also the individual installers for 32 or 64 bits, and are what I recommend for you .
https://www.divx-digest.com/software/xvid.html
The next time you record something using Bandicam to then edit in Vegas, set the audio to PCM type Bandicam … this will cause the audio stays much higher than would be if MP2, but this will be accepted by Vegas .
Well, you should be reading many mistakes in this text, do not speak your language . -
Chris King
October 22, 2014 at 8:24 amA lot of users want to import their AVI videos in Sony Vegas for editing. However, most of them encounter the importing problem while trying to transfer the AVI files in Sony Vegas directly if you search the problem on Google. Some of them can import the AVI video in Sony Vegas, but finally they just got a video without audio, the others even can not import the AVI videos to Sony Vegas with error problem. As we all know, there are many codec for AVI format videos. So although Sony Vegas Official website announced that it can support AVI videos smoothly, then users still met the problem while trying to open the AVI videos in Sony Vegas owing to the codec problem. Then how can we get rid of this problem? The easiest and fastest way to solve this problem is to transcode AVI videos to MPEG, the most compatible video format for Sony Vegas.
Jane Kong
December 5, 2014 at 6:40 amNot sure if you problem has been sovled. Then you must aware that AVI is just a “Container” , figure out the codec in it then convert them into another format if necessary.
