Activity Forums VEGAS Pro Sony Vegas 9.0b: Trouble Rejoining Audio Segments
  • Sony Vegas 9.0b: Trouble Rejoining Audio Segments
    Posted by Jonas Hardwell on October 22, 2009 at 4:02 am
    heylo all!
    i’ve been using Vegas on and off for many years, but i’m having trouble
    doing some what i consider simple audio waveform editing in Vegas 9.0b.
    i have some audio that has been cut into sections and needs to be
    spliced back together. in the past, i have been able to overlap two waveforms
    (with auto crossfades off), zoom in extremely tight and sync them up exactly while they are overlapping.
    my problem now is that when i drag one waveform over the other,
    Vegas makes the waveform further down the timeline dominant.
    one waveform completely covers up the other. i need to see both
    waveforms so i can line them up correctly.
    i’ve searched for a switch or an option, but i can not seem to find it!
    also, how can i make it easier to see the waveforms once they are overlapping?
    using crossfades, i can barely see the waveform underneath.
    thanx for the help!
    sir demon brown
    Mike Kujbida replied 16 years, 10 months ago 2 Members · 1 Reply
  • Mike Kujbida
    October 22, 2009 at 12:59 pm
    Drop the second audio clip down to a new track.
    This way, you’ll be able to see both waveforms clearly and still (kind of) hear the overlap/crossfade.
    When you get them properly lined up, move the lower audio clip up to the same track by clicking it to highlight it and using the numeric 8 key.
    The track height can be increased to make it more visibile.
    You can also loop a small section of the timeline and have it play over and over again as you slide clip #2 forwards and backwards to adjust it.
