Sony Vegas 11 – Very slow playback in Preview window
Amit Parekh replied 13 years, 10 months ago 5 Members · 27 Replies
Mike Kujbida
November 4, 2012 at 12:23 pmJames, are you exporting a series of stills from Cinema 4D?
I usually get TGA files from the animators I work with.
As long as they’re sequentially numbered and in a single folder, the process is painless and timeline playback is smooth.
I only have an i3 at work so I usually have to drop it down to Preview/Auto to get 29.97 playback. -
James Muckle
November 4, 2012 at 12:28 pmYeah, I export a scene into Png Frames that are all numbered; Sony vegas works out where each frame needs to go automaticly.
Stab in the dark here but it seems that Graphics card acceleration doesn’t make a difference to the playback quality; Would this mean that my Graphics card isn’t usable by sony vegas improve video playback? -
Mike Kujbida
November 4, 2012 at 12:39 pmDumb question but are you using the “import still image sequence” that I described?
To answer your question, yes it is possible that your graphics card isn’t making a difference 🙁
Have you tried disabling it to see if that helps?
What driver version are you using? -
James Muckle
November 4, 2012 at 12:51 pmYeah, i go to;
File > Import > Media > (find the first frame of the sequence) > Tick the box at the bottom for “Open still image sequence”My graphics card is a Gigabyte – GeForce GTX 560 Ti and it is currently on version 306.23 in the NVidea control panel. It seems that even when I enable/disable the GPU acceleration doesn’t make any difference to the playback, Should I get a new graphics card do you think?
(also I’m a gamer so I would want to get the best Graphics card to play the games 😉 )
Mike Kujbida
November 4, 2012 at 12:59 pmYou’re doing everything right so I’m stumped as to why you’re having problems.
I know that Graham has the same graphics card that you do so hopefully he’ll jump back in and let you know what driver he’s currently using. -
Graham Bernard
November 4, 2012 at 1:18 pmWatching Abu Dabi F1….
Here’s my drivers: Graphics Card Driver:- Installed : 24 Oct 2012 | Ver : 9.18.13.697 | Date : 02 Oct 2012
G
James Muckle
November 4, 2012 at 2:07 pmOk, downloading that driver.
If it doesn’t work for whatever reason, what should i do to fix my problem?
I’m completely stuck with what to do… -
Graham Bernard
November 4, 2012 at 2:11 pmI’d like to see you render out to something really simple, like an AVI and import THAT into a new Veg, and see if you get better FPS.
G
James Muckle
November 4, 2012 at 2:14 pmYeah, I did that but unfortunetly no good 🙁
Is there any more information you need to help try to locate the source of the problem?
Graham Bernard
November 4, 2012 at 4:05 pm[james muckle] “Yeah, I did that but unfortunetly no good :(“
If you can’t even play an AVI that Vegas has rendered then I have nothing else to suggest.
Sorry
Grazie
