Sony Vegas 10 only showing top left corner of my videos
John Rofrano replied 14 years, 7 months ago 10 Members · 35 Replies
Jon Kaauwai
October 25, 2011 at 11:35 amThanks JR.. now im havring the problem that every time i load a video Sony Vegas freezes and i cant do anything 🙁 although it does show the full screen now… it freezes 🙁
John Rofrano
October 25, 2011 at 4:06 pm[Jon kaauwai] “Thanks JR.. now im havring the problem that every time i load a video Sony Vegas freezes and i cant do anything 🙁 although it does show the full screen now… it freezes :(“
Is this the .TS file from recording as AVCHD? That works for me.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Stephen Leavitt
October 25, 2011 at 5:07 pmI’m having the EXACT same problem! MP4 format was working when I did 480p when I captured in 720p it only showed the top left corner 🙁
When I try Playstation 3 or AVCHD format Vegas freezes 🙁
PLEASE HELP!!!
Stephen Leavitt
October 25, 2011 at 5:09 pmI would like to know what format to change MP4 to how to do it also, thanks!
Nicole Taylor
November 4, 2011 at 10:15 pmHi, I had the same issue until I stopped using the saved xbox360 format option, use the AVCHD option when you start the HDPVR software to record and it should open just fine in vegas. Hope I helped!
John Rofrano
November 4, 2011 at 10:40 pm[Nicole Taylor] “Hi, I had the same issue until I stopped using the saved xbox360 format option, use the AVCHD option when you start the HDPVR software to record and it should open just fine in vegas. Hope I helped!”
Yea, it’s really important for HD PVR owners to understand that the formats are SAVE formats and have nothing to do with what you are recording. People get confused and select Xbox360 because they are recording Xbox gameplay. That’s not the way it works.
If you select XBOX360, you will get files that are meant to be played back on an XBOX360. This has nothing to do with the fact that you are recording from an XBOX360. So you should always use AVCHD if you want to use the recorded files on a PC.
~jr
William Stirling
December 30, 2011 at 11:54 pmHello im am using my Hauppauge HD PVR when i save my videos in an Xbox Format The video is in the top left hand corner
Now If I Save Them In a AVCHD Or The Playstation Format My Sony Vegas Crashes Someone Help Could Be Highly AppreciatedP.S Sorry about late replay i only just start using CreativeCow
John Rofrano
December 31, 2011 at 6:12 pm[William Stirling] “Now If I Save Them In a AVCHD Or The Playstation Format My Sony Vegas Crashes Someone Help Could Be Highly Appreciated”
The AVCHD format will created .TS files that edit fine in Vegas. If you are having problems with this format it may be a codec conflict. Make sure that you don’t have any codec-paks installed (like K-Lite) as these will interfere with Vegas’ normal operation.
~jr
William Stirling
January 9, 2012 at 11:28 amThank you i figured out how to get it working i convert the AVCHD with a HD Video Converter to a .wmv file and it works fine and vegas thanks for your help.
John Rofrano
January 10, 2012 at 11:31 amWMV is a horrible format to be editing and will introduce it ‘s own problems. I wouln’t use that if I were you. You would be much better of converting them to HDV using the MainConcert MPEG2 format.
~jr
