Activity Forums Apple Final Cut Pro Legacy slightly ot – animated gif from video
  • slightly ot – animated gif from video
    Posted by Gunleik Groven on February 15, 2007 at 3:42 am
    Hi.
    I am to deliver the pay-off of an hd originated commersial as an animated gif.
    The project is FCP/Shake
    What I am thinking is along the lines of
    Scale
    Export as image sequence
    Drop every 2nd image
    Gunleik
    Tom Brooks replied 19 years, 6 months ago 2 Members · 1 Reply
  • Tom Brooks
    February 15, 2007 at 2:27 pm
    Photoshop or Adobe ImageReady have features for creating animated GIFs. This should be a good way to get them properly formatted.
    Here’s a quote from the Photoshop 7.0 help.
    You can easily create animated GIFs from existing one-layer-per-frame images in Adobe Photoshop file format or from a group of single-layer images.
    You can make each layer in a multilayer Photoshop file a separate frame in the Animation palette. The layers are placed in the Animation palette in their stacking order, with the bottom layer becoming the first frame.
    You can also import a folder of files and use each file as a frame in ImageReady. Files can be in any format that ImageReady supports. Each file becomes a frame in the Animation palette. The files are placed in the Animation palette in alphabetical order by image filename.
